That’s perfect!
Can’t wait to hear how the timbergroves do for you. I may switch to them down the road.
Did you say what you are using for air?
Looks great. Clean install. What did you use to cut the factory rear brackets off? I need to do the cut kit on my 4” rear drop.
I’m more impressed with how clean everything is lol.
I'm impressed with the after adjustment readings. I've been running the IHC upper arms, but I like the look of the MaxTrac arms. Just curious, why didn't you get the thrust angle closer to zero with the track bar?
Ideally, adjustable control arms would be the way to go. If your axle is way off center, it can affect thrust angle. I'm looking at the core4x4 adjustable upper and lower arms so I can also adjust my pinion angle. How do the Timbergrove air bags ride in the rear?Would the track bar fix that? Or would adjustable control arms be needed? I thought the track bar just adjusted the rear axle side to side, not front to back. I’ll admit that I don’t really know what all those numbers mean. I’m learning all of this as I go. I was kind of in a hurry by the time they finished. They said it all aligned properly, so I paid and left.
I installed QA1 dual adjustable shocks on mine with the IHC rear setup. Been adjusting compression and rebound slowly and driving a few days to get a feel for the adjustments. Getting really close to my ideal ride feel. Its amazing how much difference 1 click makes.I was considering adjustable control arms as well. The bags ride fairly well. Definitely a stiffer ride than factory. Maybe some better shocks will help.
				What about running the airlift system? It doesn’t have a tank, but is it needed with just the rear bags? It’s half the price as well.
WirelessONE with EZ Mount - 25980EZ | Air Lift Company
Air Suspension and Air Managementwww.airliftcompany.com
