superlubricity
- Sep 7, 2019
Joining. Same issue here.
Thx for the tips. It’s a good work around. I’m going to keep pursuing a fix. Uconnect weren’t answering my calls today.Mine does the same thing.
Here is a work around:
Run the UConnect Ap on your phone
Click the "Location" in the bottom right corner (On the Ap on your phone)
Bottom of the screen says Google Search, type what you want to navigate to.
Select where you want to go, and you'll see the Pop Up on the Map that says "Send & Go". Click it.
It will send it to your 12in Uconnect Screen. You need to accept it on the touch screen (on 12in Screen) once it shows up or click the navigate (On 12in screen).
Other issue, if you want to Navigate on the 12in Screen, you don't type the address on the search bar. You have to click the "OTHER DESTINATIONS" on the bottom. Then Select address. Follow it thru and it will work.
Hope this helps until this gets fixed.
