I just checked on the build site, it generates a conflict with the protection package, but not with the ORP.
Does anyone know if they make the bedstep for both sides of the bed? Or is it the same step?
Well that sucks........can't be hard to do. Just reverse the CAD drawing and hit "print." Do these people think there are only right handed/footed people in the world??Road side only.
I'm not sure what the difference is, but when trying to get a bed step from my dealer he said there is a new part number now.
Part # 82215289AD is in development, so it's not available yet!
I don't know what has changed, he can't quote a price yet either.
I emailed AMP Research to see what they had and they replied that they have a new version for the 2019 truck out also, it's new and available sometime later in January. According to AMP the part number for their version for the 2019 RAM 1500 is : 75322-01A
It could be something as simple as a different non slip coating on the step, different grade bolts, or maybe a different casting material to make it stronger. I doubt there will be an actual "design" change, just a revision to the previous model.I wonder what had changed in the "new" version?
My bet is they will add a mounting point on the step frame for the wiring harness.
Ordered mine from mopar America came to ny in 5 days. Installed and the thing is mint! Saved my knees on the bedliner. Can’t thank you enough for the help and postHere you folks go.... View attachment 5004
The last letter of the part number signifies the revision, so a part number ending in "B" is the first revision and "C" is the second revision and so on. But the part has the same application.One site says the 82215289AB is for trucks with single exhaust only. Is that true? I presume whatever the answer is, that the 82215289AD is the same.
I did read some reviews on people who was trying to use old one and they confirm that the previous version doesn't work(I wonder what had changed in the "new" version?
