Mopar_maxi
- Feb 22, 2020
How do you like the hellwig with the drop?Which is fine because these OEM tires suck anyway. lol
Thats originally an ORP truck.
maxtrac struts up front, with a cut ORP coil (the ORP coils make the truck sit ~1” higher than “stock”). I’d have to go out in the cold to measure exact ride height on front end now; I can’t remember right off.
Out back are Timbergrove CRM 6Low bags. The rear will bottom out on the 4link tab between axle and frame, I’d have to add IHC’s cut kit to get the rear any lower.
Plus whatever supporting cutting/drilling I had to do originally with rear track bar bracket mounts and etc; when I did it nobody acknowledged that the ORP was anything but springs & so I had to go through and sort that part out. Seems like I had to drill the mount because of a mounting issue with the ORP, and adjustable rear track bar to get the back end in line again.
Rides like a slammed truck. Wife and kids won’t complain on long road trips as long as I have enough air in the back suspension, otherwise it rides like a truck that has 0 rear suspension. This picture is at a comfortable ride height, I’ll see if I have one with the rear as low as I can get it without further modification (it’s about 1-1.5” lower than the pic in back)
I’ll be installing my maxtrac and airbag kit here in a couple weeks. I’ll do a write up and vid while installing.
That looks great. The look I would love to do on mine, but can that tow a loaded car hauler? I love the look of a lowered truck, I just need to retain the ability to tow without riding the bump stops. I sure wish both were possible.3/5 ihc kit on mine, drives and rides great, have never bottomed out.
View attachment 120425View attachment 120426View attachment 120428View attachment 120429
You can. That’s what the airbags are for
I went with these
http://www.moes-performance.com/mobile/Product.aspx?ProductCode=60824
From what I’ve heard at least with the maxtrac 2/4, there are clearance issues with aftermarket tail pipes.Anyone that’s running a 2/4 or 3/5 have issue with aftermarket cat back interference? I have a Borla on mine and clearance already looks tight with rear leveling springs.
I’m on a 3/5 IHC drop with borla atak cat back. Clearance is very tight lol. I have about a 1/2” clearance from the tail pipes to my spohn panhand bar. With my helper bags in the coils I’ve never had issues hitting my tail pipes.Anyone that’s running a 2/4 or 3/5 have issue with aftermarket cat back interference? I have a Borla on mine and clearance already looks tight with rear leveling springs.
IHC and Maxtrac both make great kits. The only problem with IHC is the shocks. So I suggest upgrading them and getting the helper bags for the coils. I tow and put my atv in the bed so the air bags help a lot and keep the truck sitting level!ok max trac only comes with a few parts? the ihc kit comes with what seems to be a more solid kit? might be selling my max trac kit and getting the ihc kit? to be honest the ihc seems more solid.
