I got some TRX take offs on my Rebel
What are you guys paying for these take off’s? I’ve got a set near me but want to make sure I’m not getting screwed.
I got my set for $1,800 in the St Louis. MO area.
Might end up trading in the truck and thinking of selling the TRXs I just picked up. I’m in the Miami area
Strong work! Looks great. I’m gonna do the 3/4 spacer for now and see. Likely adding a 3.5” lift (net 2.5” gain) over time.
Just curious - any updates on this one? Have you installed 3/4 spacers?
So I just picked up a set of TRX takeoffs and i have a 2020 rebel no air ride so my question is what is the perfect set up to run these wheels?
I want to level the truck but i havent bought a kit yet.
I also have never used wheel spacers before so i have no clue what I am doing there!
Thanks!
I’ve got the trx wheels, will add the 295/70/18 tires to check if its rubbing or not.
Ive ordered levelling kit of 3”front, & 2 rear.
Now im confused on the spasers seems like a must.
What if I changed the upper control arm will it still rub?
Or have a smaller tire size??
Hi, where did you buy the wheels?
thanks
I’m interested in a set of TRX takeoffs (wheels and tires) as well. I’m currently running a leveled ORP with 1.5” BORA spacers. Can anybody say whether the 325s will fit with this setup… or if I can easily modify to make it fit?
I have air suspension. Leveled using daystar spacers and airlinksgc level links in the front and rear.
Have TRX beadlocks and 325/60s with 1.5in KSP spacers. Little trimming and truck has no problems. 20211226_155859.jpg20211223_170417.jpg20211224_123506.jpg
Thanks, I appreciate it.
Dare I ask it: how’s your fuel mileage?
My truck says 13.5-14mpg most of the time. I havent recalibrated the speedometer or added any of the piggy back tunes (PC, Pulsar, and so on).
Im not really worried about the fuel mileage though. I was daily driving my dart which got 7-8mpg so this truck gets almost double that.
I was able to get these Ram TRX wheels and tires running on my 2019 Rebel (with no lift or leveling kit). As others have stated, I had to remove the hard plastic mud flats on the front and use an exacto knife to cut out some of the wheel liner. I also bent the small medal bracket (that the mud flap screwed into) back into the wheel well. Only issue I have is the TPMS sensor threshold that keeps telling me I need to put 55 lbs in my front tires and 45 in my rear tires. The TRX tires are designed to run 38 lbs of air pressure. Anyone find a way to reset the sensor threshold to 38 lbs?
Also have 1.5" BORA spacers
Alfaobd allows you to adjust tpms thresholds to whatever your heart desires.
I just picked up a set of the Ignition Edition wheels. Looking forward to getting them on the truck. They were wheels only so I need to put new tires on them. I don't like the looks of the TRX tires on the Rebel or other trucks. They look like large balloons to me, so I will go with a smaller tire but these wheels are limited edition wheels, so there shouldn't be too many others out them with them.
Question for you guys. I plan on putting my factory 275s on the TRX wheel. The Rebel wheel and the TRX wheel both have a 19 offset but, obviously, there's 1/2" more wheel on the inside. Someone mentioned earlier that you need approximately 3/4" spacer to maintain the gap. I currently have only 3/4" from the UCA to the tire. I take it 1/4" isn't enough space, even with the factory tires, correct?
I am looking at putting stock-ish tires (33s) on theTRX bead lock rims as well. Has anyone done this?
