HOW TO: Add Digital Rearview Mirror
Yeah I know but he says he has a 2500 pw 2024
Anyone know if this will work on a 2025?
Most likely. The CHMSL is the same as previous years, but the mirror for 2025 is new part number- 68594726AA.
Not sure if there will be any proxi alignment issues after install, since there currently no way to program to keep auto dim.
Thanks for the input! Fingers crossed a way to program these new trucks comes out soon.
I once wanted to try a 2022 Jeep Grand Cherokee digital mirror on a Ram 1500 and it didn't work but I wonder if it was the camera that wasn't from a Jeep and I used the 1500 one or because it was already a can fd
If I get BCM replaced by the dealer( swapping 2020 BCM with 2023) and they program it, will I still lose dimming of sideview mirrors?
Did you have luck with the dealer programming a 2023 BCM for you? Just curious how difficult/willing they are to do it.
Question, still gathering pieces to do my install and I ordered this mirror - Mirror with 2 Video Input Channel, no FCW or ACC - 68519111AA.
When I look at the mirror that is current installed that I am removing it has the module on it that is some type of sensor but there is no opening on the front plastic housing for it to show through or on the front windshield. The part number for the mirror is 68312206AA.
Can someone ID this and deterime what it’s for and if I ordered the incorrect digital mirror? My ‘24 doesn’t have FCW or ACC.
View attachment 196947View attachment 196948View attachment 196949
Do you have auto high beams? That looks like the camera for it.
Yes,I do…. But this sensor is behind the plastic housing for the mirror and doesn't have clear line of sight forward.
That’s the sensor for auto high beams. You’ll lose that feature by installing the DRVM, since there’s no such thing as a DRVM that has the auto high beam sensor.
Thanks. And I stand corrected. There is a small notch for the sensor in the plastic.
Are the part numbers the same for a 2023 2500. Mopar website says they won’t fit?
The 23 and 24 are different from 21-22, the 23 is 3.0 and works with an image processing module while the 21 did not require it, it was just a mirror and camera.
Would I be able to just buy the 22 chmsl and drvm and have them fit without the processing module?
You can do that. You’ll get a message in the cluster on each startup that says rear view mirror unavailable, but it goes away after a few seconds, and everything works as it should.
Appreciate the replies what’s the part numbers? I don’t have ACC or FCW
Surround view cameras, or not? If not, do you have a cargo camera, or no?
