HOW TO: Add 360 Surround View Camera System
Good news finally. I am calibrated and working!! I have no idea how it worked. I reversed all the Alpha changes and then redid them under the MY23 body computer. Still ended up failing immediately without a calibration screen. I decided to try using windows Alpha, and as soon as i connected to the CVPM, the truck went haywire, cluster flashing on and off, lights on and off, switches on and off, thought I was going to end up at the dealer with my tail between my legs. I disconnected the battery for a bit, and restarted the truck, everything seemed to be back to normal. I then retried calibrating with my android tablet, and instantly got the calibration view!!! Front camera took a few tries, but the other 3 went first shot. Thank you all for your help, much appreciated!!!
That's great to hear. Guess it needed a reboot.
Wow. Finally. Congrats! Been watching your saga for a while now. Glad you finally got it working. (y)
Anyone still have a spare set of mirror camera brackets? Willing to pay.
Borrowed image from this thread
I also need a driver's side mirror replacement. Mines not broke just the tabs are super loose fitting now. So if someone has a set of mirrors they canibalized the cameras from but didn't need the brackets, I'd buy them off you.
Guess this one is dead. Still looking for the camera brackets that go in the mirrors.
A part number does not exist or the camera brackets by themselves. They're only available in the mirror assembly.
I believe I have one on my bench you can have if you pay for the trip. Shoot me a PM and I'll check when I'm back home tonight.
After installing the 360 Surroundview Camera System, I decided to put this together to help others. I know there are several others who have done this. If you have any extra input, please let me know. I will start with the parts list first. Make sure to read the notes. You may need to find the correct part number depending on your configuration or color. It was about $1200 using used items. About $2200 new.
Parts List
1 of CVPM - 68318033AI (Uconnect 4) or 56029964AF (UConnect 5)- This goes in the passenger kick panel. It comes with the mounting bracket.
4 of Camera - 68144068AD - It is the same camera. To save money, I bought used mirrors off of eBay and took the cameras out of them. The mirrors don't need to be in good condition.
1 of Driver Side Mirror - 68276511AG - These vary depending on blind spot monitoring, cap colors, and other options. I bought used ones from eBay.
1 of Passenger Side Mirror - 68276510AH - These vary depending on blind spot monitoring, cap colors, and other options. I bought used ones from eBay.
1 of Front Camera RAM Mount - 68341467AC - This could be different depending on the grill you have.
1 of Front Camera Bracket 1 - 68341480AB - Holds the front camera in the RAM mount.
1 of Front Camera Bracket 2 - 68365873AB - Holds the front camera in the RAM mount.
1 of Tailgate Handle - 6RN80GW7AA - This will vary depending on the color and type of tailgate you have. Replace GW7 with your color code that you can find on the placard on the inside of the driver side door.
1 of 68529657AA - Tailgate handle spacer. This holds the camera in the tailgate handle.
1 of 16.5' Fakra Z - Male to Female Amazon.com - Front Camera to CVPM
1 of 10' Fakra Z - Female to Female Amazon.com - Driver Side Mirror to CVPM
2 of 6' Fakra Z - Female to Female Amazon.com - Pass Side Mirror to CVPM, CVPM Output to Radio
1 of 6' Fakra Z - Male to Female Amazon.com - Rear Camera from Radio to CVPM
1 of 3' Fakra Z - Male to Female Amazon.com - Tailgate Camera Adapter
2 of #6 3/8 Stainless Screws - These are needed to install the front camera in the RAM
1 of Front Camera Jumper Harness - 68322480AD - This isn't really necessary, but it allows you to disconnect the camera easier when removing the grill.
1 of Wiring Harness for CVPM - Jimmy07 can make this for you. Just send him a PM.
Keep in mind that some of the parts listed above need to be researched depending on options on your truck.
The install is pretty simple, but time consuming. I am not going to go into detail on each item. I will give an overview. You can find videos and instructions on removing the items on YouTube and here.
Front Camera:
You need to remove the grill. Once it is removed, you need to remove the RAM letters and replace it with the new one with the camera. Too me, this was the longest part of the build. You can install the jumper harness now too.
Rear Camera:
You need to remove the tailgate handle and replace it with the one with the new camera. And NO, you cannot use the old camera. The new cameras have a wider degree of view. Use the Tailgate Camera Adapter cable in between the factory cable and the new camera.
Driver's side and Passenger side:
Replace the mirrors with the new ones. You will need to install the cameras in the mirrors unless you bought used ones off that already have them installed.
Running the cables:
I ran the front cable down the driver's side and went through one of the firewall rubber gaskets. Make sure to seal it back. I then ran the driver's side mirror and this one together under the dash over to the CVPM. The passenger side doesn't need much running as it is right there. You need to remove the radio. You will unplug the rear camera and plug in the cable to run it to the CVPM. Then plug the other cable into the radio and run it to the CVPM.
CVPM Install:
Remove the passenger side kick panel and install the CVPM. You can hook up all the cables. The CVPM is labeled for the different cameras. Then hookup the wiring harness and run it over to the fuse box. Make sure to plug it into one that comes on with remote start.
AlfaOBD Changes:
You will need an MX+ or switch the cables around. Again, I am not going to go into this as there is information about it already. If you have issues finding the settings, use the search in AlfaOBD.
VehConfig 1: Rear View Camera- NO
VehConfig 2: CHMSL Camera- NO
VehConfig 7: Full Central Vision Processing Present- YES
ECUConfig 3: Rear Camera Present- NO
Radio & Connectivity: Rearview Camera Zoom Buttons Present- YES
Radio & Connectivity: Surround View Camera On/Off Softkey Present- YES
CustSetMenu 1: Rear View Camera Gridlines CSM Present- NOT PRESENT
CustSetMenu 1: Rear Camera CSM Present- NO
CustSetMenu 2: Rear View Camera Delay CSM Present- NO
CustSetMenu 2: Surround View Camera Gridlines CSM Present- YES
CustSetMenu 2: Surround View Camera Delay CSM Present- YES
Cabin Net: CVPM Central vision processing- ENABLE
Once you do this, you should be able to at least see the front and rear cameras in the surround view display. You will now need to calibrate the surround view cameras. This is what you need the MX+ for. Plug in the MX+ using the SGW Bypass. You'll have to calibrate the cameras when you're done. Find an area that you can drive straight at about 4mph for about 400'. Connect to the CVPM in the radio module list. Run the camera calibrations individually for each camera.
Enjoy your new camera system. If you have questions, please post them in here. If I get more time, I will add more details. If anyone has more details to add, let me know and I will add them.
Looking at this old post, do you know if this will work with a ram2500 I connect 4? The mirrors I have look different I have towing mirrows, also the “ 1 of Wiring Harness for CVPM “ Not sure who jimmy07 is. Thanks ahead of time
Hey all - Wondering if anyone else's display looks like the image below...
Pic was from the install on my UC4 system. Have since upgraded to UC5 with new CVPM and it looks the same after calibration. Did I end up with a dud camera in the front? Not that noticeable until there are lines involved.
Does anyone know how to get rid of the extra lines? I got the whole thing together and it started to work on first try but now I have the extra grid lines. I disabled them on alphodb but still on
There is a setting for both the factory grid lines and then a setting within the Phoenix radio settings. Might check the Phoenix settings to find and turn them off
I looked all over for the setting on the Phoenix I'm almost tempted to install my 8.4 back to see. I disabled all gridlines on the bcm with Alfodb. I will try tomorrow again. But at least it works I have heard horror stories with some people and they gave up with cvpm
That's definitely a setting in aftermarket stereo. It isn't a factory thing. I disabled on my Phoenix head unit only have the factory one now.
I couldn't wait till tomorrow but disabled the lines through Phoenix radio thanks!!!¡
i wish it was possible to add the cameras to the existing mirrors or just by the bottom molding with camera mount, the mirrors are hard to come by and they are 750 for new ones.
If your mirrors are good then you find used ones like I did on ebay for 250 and 300 and only had to swap small parts on one but the other I had to replace all the guts cause power fold was shaky. Mainly all you need is the camera and bracket to install on stock mirrors but bracket not available.
Like said above. Just buy used mirrors and swap over the components. You just need to drill out the hole. I'm working on a guide. Just haven't had time yet.
Hello Experts,
I have a Ram Limited 2020 with the UC4 factory 360 Sorround Camera System.
I did an upgrade to UC5, to have the new 12” screen and full-size capability with Apple CarPlay.
I bought the following parts and made some changes:
  • CVPM new Par #56029964AF
  • 12” Screen
  • Radio/NAV module
  • RAM 12" UCONNECT 5 RADIO INTEGRATION PROGRAMMER + SECURITY BYPAS CABLE
  • The UC4 to UC 5 INTEGRATION WIRING HARNESS ADAPTER
  • In Body computer Year 2023
So far everything works as expected, except for the 360 Surround Cameras.
I can see all the cameras active individually (Mirrors, Front, Rear), but I cannot see the 360 nor the active gridlines.
I tried AlphaOBD; Radio>CVPM>calibration: but it triggers a lot of alerts on the Cluster and does not allow me to. Tried on the dealer with the Mopar OBDII and the calibration also fails.
Any tip or recommendation on the Alpha, to try to make the Surround works?
Thanks in advance!
Hi, a bit late to the party but I just bought a 2023 3500HO in Australia, annoyingly the imported these in Laramie night edition but without the cameras, dealer quoted me upwards of 22kAUD to install it and after paying over 200kAUD I dont have an appetite to be ripped.
Will this parts list work with the truck I have?
Cheers
Georges
