After much contemplation, supplication and my sweetie asking me when her truck was going to be ready to roll, I decided to go ahead and mount the new Hellwig sway bar as is. So let's get her done!
I used a stone dril point to true up the deformed whole on the left side. The right one is good enough, I guess.
I first covered the bare metal on the cleaned up hole with some Mopar PS2 silver. But it didn't match the "hammered" finish of the rest of the sway bar.
Instead, I went with a semi-glass black. That and satin black are my detailing defaults. So I already had some.
It turned out pretty well. But using the stone drill point will come back to haunt me later in the project.
This job doesn't take too many tools. I used the following:
- 3/8 impact with 15mm socket to remove the sway bar shackles.
- 3/8 ratchet with 8mm socket to hold the sway bar links while removing and installing the nuts.
- 18mm ratcheting end wrench to remove and install the sway bar link nuts.
- 3/8 torque wrench set to 30 ft. lbs. with extention and thin-wall 15mm socket to tighten sway bar shackles.
- Locktight for sway bar shackle bolts.
- Plastic electrical tape and box cutter to protect left speed sensor lead.
- Large carpeted floor mat to stay comfy while under truck.
Here's the factory sway bar. It's hollow, lightweight and likely does very little to prevent sway.
I started by removing the sway bar shackle bolts with the impact wrench. This will be the only use of the impact wrench on this project. With the factor shackles, a regular impact socket works fine.
Here's how to remove the nuts from the sway bar links. I held them with the ratchet and 8mm socket and removed the nut with a 18mm Gearwrench ratcheting end wrench.
Next I prepped the new Hellwig bar using the old bar for comparison. And yeah. I DO live in a pine thicket.
I was very liberal with the supplied bushing grease. I used most of the tube and I did apply a thin layer to the shackle side of the bushing as well. Polyurethane loves to squeak. Can't have that on our new truck.
*** MORE TO COME IN NEXT POST! ***
