so @securityguy , complete bonehead here. I can run a code blue, but wiring electronics is DEFINITELY not my strong suit. Installed a Viofo A129 Pro duo but want to wire it into my fuses.
IS this the right Viofo kit I should be using? https://www.amazon.com/Viofo-3-Wire...1CCZGL/ref=psdc_3248689011_t1_B07JQ1JYPJ?th=1
Next, I downloaded the awesome fuse layout PDF by HAL9001, which fuses should i be tapping into? 66 for ACC and 33 for Battery, or should I be looking elsewhere?
Finally, which voltage settings do you recommend? 11.8/23.6, 12.0/24.0, 12.2/24.4, or 12.4/24.8.
Thanks in advance!
Thanks in advance!
