So I got my rear camera installed today and I still do not have any issues with my TPMS or FOB, everything is functional just like the day it came from the dealership!  I watched him install it, the cable was run from the back camera, the rubber molding was removed from the passenger side and the cable tucked up under the headliner to the camera at the front. He removed the passenger a-pillar and ran the excess cable down to the access door on the side of the dash. Neatly coiled the excess cable and zip-tied to a metal bracket. As you can see in my pictures, my cable is way thicker than the hard wire kit cable. Heavy duty and doesn't bend as well, but I think it's good for no RF interference and more robust.
As for the bracket, I borrowed
@Billy James idea with the vinyl tile FREE samples from Home Depot.  I cut it so the same dimensions 2" wide and 3" long, the only difference was his bracket was bent at about a 45deg angle which is what I originally did but it was pushing the liner up slightly and it didn't sit as good.  I decided to bend a new one at a 95deg (approx.) angle which I find was a littler better. It almost made it more like a "hook" into the plastic and the liner pushed down onto the bracket. It pretty much could have stayed there on it's own, but I wasn't going to take chances with a camera attached so I put double side tape on it and attached to the factory plastic molding. I think it works out great and it again it was FREE!!!  So thanks to Billy James for the idea and saving me a bunch of time racking my brain for a good way to make a custom bracket.  I did also, peel off the vinyl design on the face of the tile sample and the backing, then I sanded it down and painted it with some satin black paint I had left over from painting my center caps on my rims that were just powder coated. I will say the 3" length is needed as you can see in my pictures, any shorter and the cable end would be into the headliner and would probably cause problems. So if you plan on making the same bracket, I wouldn't cut it any smaller then the 3" length.
Anyhow check out the pictures, I am very satisfied with the camera so far and the install. I did move the front camera down slightly as I wanted to be able to see the record light with a slight tilt of my head. Where it was positioned before, I had to dip my head down far and look up to see the lights. I wanted it up higher but I have the tinted eyebrow and being too close to the mirror picked up the mirror bracket. All in all I am happy..
Side note: I can't believe the size of the box for the rear camera that is so small compared to the box for the front camera which is larger. Packaging is crazy.
View attachment 69575View attachment 69576View attachment 69577View attachment 69578View attachment 69580View attachment 69581View attachment 69582View attachment 69584
