SnowBlaZR2
Fuel Economy Champion
Because not everyone wants or needs a 33 gallon tank.Wow I can't imagine a truck with a tank that small. I wonder why they don't just build em all with the 33.
But why though? What's the point in running the tank so low? Obviously it's not just 1 person doing it, but I've never understood why people don't fill up sooner. In Germany they'll write you a ticket if you run out of fuel on the Autobahn, and I really wish they did that here. It annoys me to no end when there is traffic hazard because someone ran out of fuel which is completely avoidable. Maybe you guys can make sense of it. Is there an actual reason why people run it so low?For me when the Range hits 10 mi/Low there is about 2 gallons left in the tank.
And on a side note. I have no idea what size tank I have, but it's not the 33 gallon since I don't see an optional tank size on my window sticker. I can't find any specs for my truck either. Every publication for tank sizes that I find only list 3.6L for the Quad Cab, so I don't know if the 5.7L has a different tank or not.
5.7 gets a 26 gallon if you don't have eTorque, and 23 gallon if you do.But why though? What's the point in running the tank so low? Obviously it's not just 1 person doing it, but I've never understood why people don't fill up sooner. In Germany they'll write you a ticket if you run out of fuel on the Autobahn, and I really wish they did that here. It annoys me to no end when there is traffic hazard because someone ran out of fuel which is completely avoidable. Maybe you guys can make sense of it. Is there an actual reason why people run it so low?
1. people are poor and do not like to fill up oftenBut why though? What's the point in running the tank so low? Obviously it's not just 1 person doing it, but I've never understood why people don't fill up sooner. In Germany they'll write you a ticket if you run out of fuel on the Autobahn, and I really wish they did that here. It annoys me to no end when there is traffic hazard because someone ran out of fuel which is completely avoidable. Maybe you guys can make sense of it. Is there an actual reason why people run it so low?
I only do it on the highway.But why though? What's the point in running the tank so low? Obviously it's not just 1 person doing it, but I've never understood why people don't fill up sooner. In Germany they'll write you a ticket if you run out of fuel on the Autobahn, and I really wish they did that here. It annoys me to no end when there is traffic hazard because someone ran out of fuel which is completely avoidable. Maybe you guys can make sense of it. Is there an actual reason why people run it so low?
LOL well that makes sense. I always tried to treat 1/2 tank as if it is empty. Instead of saying oh crap I need fuel when it's at 1/8 tank, think that at 1/2 and fill then instead.1. people are poor and do not like to fill up often
That makes sense. On a road trip, stopping frequently can be bothersome for most people. I don't typically go below 1/4 on a trip through. There may be a sign (or a known station) 15 miles away, but there's no guarantee that it isn't closed. Or maybe the exit is closed/blocked. If you've got a 1/4 tank or more you can miss that exit and not run out of fuel. If you're 20 miles to empty and were banking on that stop in 15 miles, you're screwed.I only do it on the highway.
When the wife/kids need a break we use the rest areas since they are an easy off/on ramp without actually getting off the highway. They rarely have gas
The highway is very easy to map out gas stations. So I know exactly how far I can make it.
This maximizes driving time for us.
Well isn't that just awesome.FCA RAM
fcacommunity.force.com
Enter your VIN here
Yup I've got 26 gallon tank according to the build sheet. You nailed it.5.7 gets a 26 gallon if you don't have eTorque, and 23 gallon if you do.
Get the My Ram app for your phone, sign up, sign in add vehicle and VIN, scroll to the left on the bottom menu and select Your Vehicle EQUIPMENT, will give you all the info attached to that VIN.And on a side note. I have no idea what size tank I have, but it's not the 33 gallon since I don't see an optional tank size on my window sticker. I can't find any specs for my truck either. Every publication for tank sizes that I find only list 3.6L for the Quad Cab, so I don't know if the 5.7L has a different tank or not.
I found something interesting today, a post from the 33-gallon tank swap thread said if you have a 26-gallon tank, your Fuel capacity setting in the BCM should be at 98 liters (26 gallons = 98.4207 liters) so I looked at my Alfa file and it states Fuel Capacity (36-290 L): 93.000 Liters (93 liters = 24.568 gallons).
I think RAM set it up like that to have some cushion or reserve fuel to avoid people running out. Right now my low fuel light comes on at 50 miles DTE and the gauge is showing 1/4 tank. I plan to use Alfa and change it to 98 liters as my window sticker and build sheet both show a 26-gallon fuel tank and see how that affects the gauge and DTE miles along with low fuel light.
No reason to be scared of gas stations. If you want to avoid them, maybe a truck isn't the right vehicle for you.I have the 33-gal tank and wouldn't want anything smaller. I bought this truck to drive not sit in the garage only to be used as a hauling vehicle. The less time I spend stopping at gas pumps the happier I am. On my first fill I was at 1/4 tank, and it only took 22 gallons. I'll be filling for the second time later today when I get to about 1/8 to see how much it takes.
The only reason I see to have the smaller tank is if the owner is not driving the vehicle as much and only refill every two weeks or so. The most ridiculous reasons I've heard is the weight issue, if the weight of 7 gallons of gas is interfering with you using your truck, then you purchased the wrong truck not the wrong fuel tank.
Yep, not everyone travels the same. Great to have options.I don't like to drive a long time in one sitting anyway. It irritates my back, so I'll only go about 2 hours or so before I stop to stretch my legs and pee, grab a snack, refill my drink, etc.
Because some people's trucks cannot handle the extra 60 ponds of gasoline. Their axels will snap and tires will blow out as they loose control driving down the road. 60 pounds is a killer...Wow I can't imagine a truck with a tank that small. I wonder why they don't just build em all with the 33.
Haha! Well yes, with the great mileage I get sometimes, it's not that far off.For me when the Range hits 10 mi/Low there is about 2 gallons left in the tank.
Yes, they are that smart
