SnowBlaZR2
Fuel Economy Champion
Lol. No.You may not need/want the 33 gallon tank, but it will definitely help when you sell it. Part of the reason I got it on mine. The 26 gallon probably would've been fine for my uses.
I'll have my truck until it dies.You may not need/want the 33 gallon tank, but it will definitely help when you sell it. Part of the reason I got it on mine. The 26 gallon probably would've been fine for my uses.
that is what I did with my 95 ramI'll have my truck until it dies.
It's smart a**es like you that make members reluctant to post their opinions on these sites. Read the post, don't try to manipulate the poster's words to fit into whatever world it is that you live in.No reason to be scared of gas stations. If you want to avoid them, maybe a truck isn't the right vehicle for you.
70 lbs is 70 lbs. If you use your truck as a truck, sometimes payload matters.
I did read your post. You said something snotty, and you got what you got.It's smart a**es like you that make members reluctant to post their opinions on these sites. Read the post, don't try to manipulate the poster's words to fit into whatever world it is that you live in.
where did Threesuns1 say they are "scared of gas stations"???No reason to be scared of gas stations. If you want to avoid them, maybe a truck isn't the right vehicle for you.
The exact same place anyone said "the weight of 7 gallons of gas is interfering with using my truck."where did Threesuns1 say they are "scared of gas stations"???
nope.The exact same place anyone said "the weight of 7 gallons of gas is interfering with using my truck."![]()
Yep.nope.
you just cannot leave it alone can you?Yep.
this is fun for me so keep it up
Not true. I have the 5.7 and 23 gal tank. Its a 2019 though, so maybe the newer trucks are optioned differently. Also, like others I have never been able to put more than 20-21 gallons in at the pumps.I agree on that, as for tank size, I believe if not a 33, you likely have a 26 unless you have an E-Torque, which can be a 23.
Good link above to check for sure, using your vin and getting the build sheet. Make sure to go through the whole sheet, it may say 23 gallons, then show the optional 26 gallons in later pages because it's part of another package. I think you can use Control F and use that to search the whole sheet.
Did it with my 96, rebuilt the engine and sold it to the next guy who will probably run it til it dies.that is what I did with my 95 ram
Most car/truck manufacturers intentionally do this because there are some people who take the estimated DTE as gospel. If the truck says 15 miles to empty and they run out in 10 miles they get pissed and blame the mfg for running out of gas (not themselves for running it that low)...... it appears that the mile counter is quite conservative.
