So everyone likes the Faisal Pro 3FE22 speakers in the dash. Has anyone tried anything else such as: Hertz DCX 87.3, Audio Frog GB25, Dayton Audio PS95, Tang Band Bamboo, etc.?
Not everyone has been happy with the faitalPROs but most have.
I have not heard/read of the other speakers you listed being used. I specifically wanted to keep the 8 ohm impedance of the OEM speakers and do not have any plans to add anything else (amplifiers, subwoofer(s), replace door speakers).
Just doing a quick Google search and comparing to the faitalPRO 3FE22-8:
Hertz DCX 87.3 - 4 ohm impedance,
looks like it would fit the dash mounts, about $35 more than the faitalPRO
Audio Frog GB25 - 4 ohm impedance, might fit in the dash opening but no way to mount it without creative modification, about $380 more than the faitalPRO
Dayton Audio PS95 - 8 ohm impedance, might/might not fit the OEM dash mounts (someone would have to buy them and test fit), are about $20 cheaper than the faitalPRO
Tang Band - Various models but the mounting holes are in the circular frame like the Dayton Audio so a test fit or willingness to modify the mounting points in the dash would mostly likely be necessary to mount the speakers.
I'm not sure what the driving force for the first person to use the faitalPROs (the first person I read about them from was
@Sonnie) but a number of us jumped on it as a direct replacement with no other system mods (replacing more speakers, bypassing ANC, adding amplifiers, etc.) and were happy with it.
The biggest limitation is the mounting location as there are only two screw holes and limited space to the windshield. Inside the dash it opens up for a good amount of room for depth, magnet size, and bass blockers to fit.
As time goes on others will branch out, try other speakers, find out how to make them work, then post up their work for others to possibly follow.
Other generations have 10+ years of trucks and people playing around with them. The 5th gen is only a few years old at this point so we've got a ways to go before there's a laundry list of possibilities to choose from that others have done.
Just my .02
