OuachitaAdventure
- Nov 2, 2018
Truck is at the dealer now. I have talked with Alex from Ram Cares about the issues as well.
Just show them theseMy RAM 1500 is in the shop for the second time in my first month of ever owning a Ram--First time was with only 800 miles and now with 2,200. The first time they said they couldn't replicate the noise I described. Today they call and again said they couldn't replicate it. So I agreed to drive the 30 minutes to my dealer to ride with the shop foreman. I only got the brakes to squeal once while he was in the truck, but at least it was the same high-pitched noise I've played for the service reps.
When we got back, the woman in service was almost questioning him right in front of me: "Is it bad squealing or just normal?" "You only heard it once..!?
I swear. I drove a Silverado 15 years before upgrading to this new RAM--$45,000 later and I've been to the service department three times in the first month. I'm trying hard to love my RAM, but the dying bird noise every time I break is ridiculous.
My dealer called me today and told me my truck was ready. They replaced the pads on the front, but didn't address the TSB for the rear. I asked them to look at the TSB # I gave them. They called back and told me they'd need to get back with me on Monday. I dont' want to have to bring it back again....
Picked up the truck and got home to read the service notes. No front brake work done!
Went in first thing this morning and didn't have the backing growl noise when backing so that was good. However, my rear camera went blue.
First in line and spoke with the asst service manager that ordered my parts. He remembered and even told me the parts department even told him there were front brake parts. He apologized, but really?
Needed my truck today so he said I could bring it in tomorrow for the front brakes, camera,and mirror noise. Will see if they can get the passenger side roof drain plug fixed too.
Come on man!
The dealer where I bought it from was giving me the run around about this issue since 11/2018. I had them take the decals off my truck and they didn't heat them up before removing and pulled paint (small rock chip look) off where the two RAM logo's are on the sides of the truck. They stated rock chips...really, a rock jumped through the RAM badge and removed paint without affecting the badge? Measurements verified they are right behind where the badges used to be. They have the best service rating in the area too...crazy. I was a Chevy guy for 25 years and also had a good relationship with the last one. Here's to hoping I can build one with RAM as well.Sounds like you and I have similar experience with our dealers. I'm going to a different dealer to see if I have any better service. My truck has been to the dealer I purchased it from numerous times now, not one trip has been a good experience. Each time ends in leaving with all or most of the same issues I came in with. Very unorganized and unprofessional.
I have my fingers crossed the next dealer will be better but I'm not getting my hopes up.
Prior to the RAM i used the same dealer (Ford) for all purchases and 100% of my service work for the last 15 years. Only reason I purchased the RAM was because I liked the new style and was just ready to have something different, figured I could build a relationship with the RAM dealer as I had with my Ford dealer, becoming more and more obvious that likely won't happen.
Looks like they found a way to correct the problem using a few brackets to increase the stiffness on the caliper by tying it into the axle housing and eliminate the vibrations causing the noise. The latest TSB is a much cheaper option probably saving Ram 100s of thousands of dollars in repair costs.The dealer where I bought it from was giving me the run around about this issue since 11/2018. I had them take the decals off my truck and they didn't heat them up before removing and pulled paint (small rock chip look) off where the two RAM logo's are on the sides of the truck. They stated rock chips...really, a rock jumped through the RAM badge and removed paint without affecting the badge? Measurements verified they are right behind where the badges used to be. They have the best service rating in the area too...crazy. I was a Chevy guy for 25 years and also had a good relationship with the last one. Here's to hoping I can build one with RAM as well.
Best of luck finding a dealer that helps you on the RAM!
This is the second and only dealer withing 30 minutes of me, the others jump to over an hour away. They are more responsive and at least own up to a mistake and offer to correct it, so that's a plus anyway.
I went through the forums and noticed newer TSB's for this brake issue. They ordered off the 05-001-19 which includes the most parts to replace (early fix?). The other two gradually remove parts for the fix and the newest one, 05-002-19 only has a kit to order which I can't find what it is. Regardless, the chewbacca noise when reversing in the morning isn't there anymore at the moment.
April 25, 2019 - Rear Brake (Moan) Noise - # 05-002-19
April 10, 2019 - Rear Brake Noise - # 05-001-19 REV. A
February 14, 2019 - Rear Brake Noise - # 05-001-19
They left the paperwork on the countertop while they went to get my truck for me. I looked through the paperwork they keep and the cost of the parts were $592 for just the back brakes. I bet you nailed it and they've found a cheaper "fix".Looks like they found a way to correct the problem using a few brackets to increase the stiffness on the caliper by tying it into the axle housing and eliminate the vibrations causing the noise. The latest TSB is a much cheaper option probably saving Ram 100s of thousands of dollars in repair costs.
Its not just the 12" screen, I think its the uconnect software in general, I have had similar issues with the 8.4. it seems like if you try changing things around while its booting up it just $hits the bed. I pushed the power button on the stereo to turn off the radio while I shifted into reverse to back up and lost the camera, no blue screen, nothing, pressed the power button again to turn things back on and nothing, took a good minute or 2 for the whole system to reset and work again properly, another time I was in a drive through and the front parking sensors were beeping so I went to turn them off while it was beeping and it locked up and just continued to produce a steady high pitch noise until I put it in park and completely shut the truck off and restarted it. Not to say only Rams do this, I had several software gremlins in my GMC intellilink as well. They just don't multitask very well, could be bad code, or just inadequate hardware for handling multiple commands at the same time.They left the paperwork on the countertop while they went to get my truck for me. I looked through the paperwork they keep and the cost of the parts were $592 for just the back brakes. I bet you nailed it and they've found a cheaper "fix".
The dealership service asst manager called me back and told him about the rear camera coming back and what I think I did to cause it, and correct it. Just in case he sees that in the future. Don't think the 12" display likes being interrupted with button pushes while it's booting up.
Told him I didn't want to bring it in tomorrow and rush mine or someone else's truck, so we scheduled for next week. He will take a look at all my other issues at that point too. Happy with their follow up and willingness to resolve my issues thus far.
Got word today that the parts for the rear brakes are backordered until 5/23. I can say that RamCares has been on top of this. I have been getting daily updates from the service manager and a rep from FCA. Really happy with how I've been treated and appreciate RamCares for reaching out to me.
