Engine stalled / shut off
Following up, got the truck back today. The dealership applied two software updates, one for the hybrid control processor and one for the PCM. It is running smoother now. I tried to get it to stall going up the driveway and all is well. Keeping fingers crossed this is the fix.
I had this problem on 04/2023 and it almost caused a major accident as well.
April 2022 my 2022 1500 Limited battery light came on, check engine light on and voltage was jumping from 10-11v. Took it to dealership and they said they reset the system and found no errors and it should be fine. April 2023, last Friday, same issues started happening, message popped up saying the truck was shutting down all non-critical systems, radio died, turn signals stopped working etc etc. I barely made it to the dealer when the truck decided to throw itself in park as I was turning into the lot. Service had to put a jump pack on it and ended up applying to TSBs. They claim a TSB for the auto stop start was draining the battery and that they applied the TSB, charged the battery, drove 20 miles and said it's fixed
Stetler Ram York, PA applied Z49. (DID NOT FIX THE ISSUE) had to argue to get them to give me a loaner.
Between 4/23 and now I've had the check engine light come on and go off as well as the battery light and low voltage. Called Stetler a few times and they claim there was no issue and it should go away after turning the truck on/off Really?!?!? My issue wasn't a stall situation like is being mentioned most places. The whole truck dies and fails to start with a dead battery.
12/27 I was on my way back from an urgent care visit with my 10yr old daughter in the pouring down rain and the truck decided to do the following
  • Display went red and stated "shutting down non-critical systems"
  • Lost power steering going around a sharp turn and almost hit a parked car
  • All kinds of lights on the dashboard lit up, no backup camera, no high beams etc etc
  • Then bam it locked up the emergency brake and through itself in park with cars sliding out of the way behind me to avoid hitting me
  • Called
    Stetler Chrysler Dealer — Stetler Chrysler Dealership and they basically told me not under warrant even though same issue 8 months ago, I needed to call ram support and get a case # and even if I did that they wouldn't look at it for 1.5 weeks as they are backed up and understaffed
  • Roadside assistance was going to take 2hrs to get to me so I had my wife by a new battery ($300) and deliver with my tools. I installed it and was able to get home but the check engine light and batter light stayed lit. Batter voltage read 11.9-12.2 bouncing around
  • I put the new batter on charge all night, drove a few miles to grab breakfast and the voltage dropped from 12.2 to 11.9
  • Ram support case #88414885 was created and they wouldn't authorize a rental car for me stating recalls don't qualify for rental cars. I asked for a manager and was told they are all in meetings. I called back asked for a manager and was told they are all on calls.
  • Called roadside assistance again and had it delivered to Keene Dodge in Jarrettsville MD.
  • Had to install my new batter to get the truck started and on the roll back as the manual neutral override cable stopped working and would not allow the truck to move.
  • have pictures and video and plan on creating a website regarding this issue, going to social media etc. Had a major issue with a Ford Explorer once where the dealer/Ford kept jerking me around and a simple website and social media seems to cost that dealership enough money that they brought me in to discuss options to have it taken down.
Wonder if 3 times means lemon law???
@RamCares What's it going to take to get this resolved and get us proper assistance? Someone need to get killed while driving their $80k truck that decides to just stop in the middle of the road with no notice? We can't deal with only having 1 vehicle with work, kids, sports etc? The fact that this is a recall (RAMS FAULT) should automatically supply a loaner vehicle.
My old post was here
Keene Dodge Jarrettsville - I called for an update today
  • "appears there is a failed component on your alternator that caused it to fail and destroy the etorque battery behind your rear seats as well"
  • "Ram has requested diag reports that we've supplied them to hopefully get this covered"
Per my understanding there isn't a "normal" alternator but rather this 48volt system that failed.
Sounds like this is the only case I've heard of this issue? Hopefully hear something back tomorrow.
Ram support did call me back to let me know this person was working the case and going to contact Keene for an update to hopefully work out a loaner vehicle since my $80k truck is dead. Still nothing back from support........
No. E torque engines use basically a starter generator, no traditional alternator. Which is covered under a 8 year emissions warranty.
Mwoods, hopefully they'll get it figured out. I just took mine back to the dealership. Was at the bank and the start pushbutton would not turn the truck off. Took a 2 min 43 sec video of me pushing the button with nothing happening for proof. Drove to the dealership and surprisingly it continued doing it at the dealership. While there the service advisor asked me if it had shut down since last week. Told him no, but that I installed a battery monitor to see if I could figure out why it was dying. Showed him the attached graph and that it seems that over time the battery continues draining down. I put the monitor on Saturday and also charged the battery fully. Looking at the graph you can tell it is slowly draining down since Saturday. I charged it last night for about 3 hours which pulled the voltage back up, then this morning you can see where the decline continues. It seems like the e-torgue is charging, but never fully, as the volts drop the e-torgue's charging drops with it. If I charge it, then it restarts the cycle. The blips are when I crank and drive it. Not sure if all this is related, but it a odd coincident that all this is happening together over a 3 week period.
Tried getting my new battery back today but the dealership insisted that it's best to let them use it to test/fix. Makes no sense to me as they should diagnose the whole issue with the stock battery that was in the truck......I didn't argue but still don't really agree.
They did mention my case (48v system) failing/dying was only the second time they've seen this issue and as I mentioned it killed the battery behind the crew cab seats as well.
Picked my truck up yesterday evening. They said the push button was failing and they believe it was causing the power drain. They replaced it. Guess time will tell if that also fixes the power drain.
Following up here: after about 3 weeks / 1000 miles I'm happy to say there has been no stalling after the PCM and HCP software updates. Feels like new again. As I'm driving I notice the voltage gauge is rock solid at 14.3V and it doesn't fluctuate like it used to. Also it runs smoother when it's very cold- as in the first 2 minutes of driving. Just thought I'd throw it out there because most people don't seem to follow up when things go well.
FCA / Ram must know about this! I see parasite law firms trying to jump on class action suits and there are a bunch of complaints online. And it's an unacceptable problem for a daily driver!! Hey @RamCares , send this one up the food chain-- A whole team of people should be fired and have their careers ended for this!! I'm also astounded there isn't a bigger recall outside of the '21 V8s. Some family driving in Houston, Dallas or L.A. -style traffic is going to get clobbered one day.
Anyway, while it was at the dealership I read all the complaints-- and considered unloading this truck, but now that it's good I'll give it another chance. I understand the technology is somewhat on the forefront, and I definitely enjoy driving it... every Dodge I've owned had initial glitches but turned out to be reliable and my favorite vehicles to drive. We'll see how it holds up!
Got the truck back on the 6th. No signs of the "generator" "48v powergenerator part" Dealership now says they were wrong and there was nothing wrong with it. The etorque battery behind the seat was bad and was replaced. Staring up in the morning the voltage climbs to 14v while idle and slightly above during driving. Only time will tell.
Battery voltage read out was down to 13.5v during a night drive. I said screw it and traded it in for a 2024 1500 Limited same specs but night edition. Had it for 1.5 days and now dealing with a vibration in the gas pedal and steering wheel at highway speeds in and around 1500-2000 rpms…….. You can make this crap up @RamCares
Not sure if this was posted before but FYI -
Just throwing my experience out there as well. I have a 23 1500 Lonestar V8 E-Torgue 4x4 20k. Have had 0 issues and this truck is my pride and joy. I took it in to the local dealership Dec 14th for oil change and for the recalls 08A and 97A. I picked it up later that day and noticed burning oil smell and figured they spilled oil on the engine and didn't clean it off. It is what it is I thought and figured I'd clean it off myself later that evening. Started worrying though about them not tightening the oil filter or drain bolt since they couldn't keep from spilling the oil, so I started watching my gauges. In the process I noticed the battery voltage seemed low ( 13.1 - 13.5 ). Didn't think too much about it at first. Then last Friday was pulling out of my sub-division, going slow and starting to get on the gas, then it shut down. Same story as others, pulled over, it shifted in to park... It crunk back up fine. But I've never had this happen before and all of sudden a week after the recall updates this happens. Same day I stopped to get gas. After filling up, I pressed the start button, as the gauges were doing there test, it all of a sudden shut off again. It never made it to cranking the engine before it turned off. Then Saturday went to crank it and it was completely dead. Metered the battery and it was showing 3.5 volts. I charged it and its been holding fine thus far. Took it to the same dealership yesterday, told them everything, they hooked it up, showed no codes and said everything seemed to be working fine and if I any more issues to bring it back to them. This is very frustrating!
Intermittent software glitch? Faulty software coding for a unique set of data inputs that the computer received at the moment? I am a boater and a musician. I have a 2020 1500 BigHorn Lonestar edition 5.7.eTorque (mistake...I hear that battery setup costs a small fortune. Do the benefits outweigh thealmost certain replacement expense?). I bought it used in immaculate shape. Prior to this truck, I had a 2008 Durango 5.7 that I had for 15 years. It is extremely frustrating to me that EVERYTHING on the RAM is software/computer controlled. The radio/climate/engine/dashboard info etc. Everything....you have an audio issue? Where do you begin? Very little is user serviceable. I bought the RAM because the Durangos are no longer trucks and are noticeably smaller and I needed something fairly beefy to pull my pontoon with. Not sure how this extra eTorque 48 volt battery is going to hold up, but just replaced the main starting battery today at 4+ years. Tried to find something newish in a stripped down more utilitarian "analog" style and came up with nothing. Not sure how long I'll keep this. It just screams "asking for trouble".
I have a '24 1500 Laramie with similar issues, last week the engine shut-off while driving at slow speed or turning (5 times). The last time all alerts flashed including ECS, AEB....after I rolled to stop and shifted to park, display changed to press brake/push start....pushing start only caused a reset of all the gauges with 2 mins between resets. Twice it started but only shutoff again after pressing the gas pedal. After 10+ minutes I got it started and rolling , heading straight to dealer.
Dealer has had truck for three days and here's the status:
Good afternoon, long txt from tech to STAR. We have checked the BPCM (battery pack control module) That tested out good the codes that are in there are for, lost communication with ECM/PCM, I have several of those codes, also lots of codes for bad data from body control module. Sent all the info off to STAR after checked power to ECM, PCM, RFH, TCM, BPCM. All are checking good so there has to be something going on in between these modules that are causing them to go active at times. STAR has been talking with the tech to see if any other vehicle have had this concern. waiting on STAR to say what they want us to do next. Im sorry that its taking so long just lots of little checks that STAR is having us check voltage to this module and that module flash updates and so on and so forth.
If any of you have this happen to you and the fix, I sure would appreciate sharing!
Update on my situation, truck was in dealer for a week. They said they couldn't reproduce it, service advisor said they applied a PCM update but work order says it was checked and it was up to date. Over the weekend, the engine shutoff happened 3 times....all while going around 20mph, the third time it took several mins for the electronics to completely reset so I could restart the truck. Going back to the dealer today, I'm starting the process of documenting this for lemon law. I absolutely do not trust driving this truck....of the 8 times its happened, once was in a busy intersection at dusk, I probably would have been broadsided if it was just 20 minues later.
  • Sad
Reactions: c3k
Update on my situation, truck was in dealer for a week. They said they couldn't reproduce it, service advisor said they applied a PCM update but work order says it was checked and it was up to date. Over the weekend, the engine shutoff happened 3 times....all while going around 20mph, the third time it took several mins for the electronics to completely reset so I could restart the truck. Going back to the dealer today, I'm starting the process of documenting this for lemon law. I absolutely do no trust driving this truck....of the 8 times its happened, once was in a busy intersection at dusk, I probably would have been broadsided if it was just 20 minues later.
Tell them to check or replace TIPM module. It's below the fuse block in engine bay and all modules run through this (CAN BUS). Had this issue on 19 and would constantly get random communication error codes (brake module failed, abs failed, 4wd failed....it would be random and change each time) after about 15 or 20 min run time and then engine shuts off. Need to shut down / reboot and restart which seems to reset the clock sort of speak. Hard to diagnose as truck would be fine at dealer but if they would take truck on 30 mins ride it would do it. Obviously this could be anything with your truck but this is what fixed my issue. Food for thought.
Appreciate another possible gremlin in this mess! The TIPM has not made the list of possible culprits from reading throught this forum. When my truck has its "biden" moment....it sequentially flashes through all the failure alerts (ESC, AEB, Airbag, 4wd, Traction Control) but the very 1st dash alert is "Speed Control Messaging Unavailable" so I think you are on to something....looking back on the occurences (9) I do believe each are 20+ mins of runtime and logs are full of comm errors. Strange though, mine only happen below 30mph. I've driven this truck for hours on freeway and no issues at all. I will talk to the tech today and make sure that's on the list, thanks.
Not too long ago someone posted a video of a private mechanic tracking down a problem where the truck would stall after some exact time like 33 minutes. It turned out to be a bad capacitor in the TIPM module, IIRC. Can anyone point me to that post? I've tried searching without any luck. Thanks!
Happened to me for the second time today. First time was about 3 months ago. Today, same location - stopped at a stop sign about to pull onto a busy road. As I pulled forward the truck
stopped abruptly, emergency brake was engaged. Dash displayed message to press brake to restart, and I think there was a message regarding Stop Assist?, but there were vehicles behind me and I was scrambling to get the truck started again. Engine very briefly ran rough as I pulled onto the road with Check Engine and Battery lights illuminated. Thought it might be a computer glitch, so I pulled over at the first available spot and restarted the engine. Battery Indicator light did not come back on, but Check Engine light is still on, so will pull a code on Tuesday (and why the heck doesn't a truck with this much computer implementation have an on-board code display?). Battery currently showing 14V. 2022 1500 LIMITED CREW CAB 4X4, 5.7L V8 HEMI MDS VVT eTorque Engine. 10,200 miles. Will report on progress.
I have a 2023 Laramie with the e torque. Twice in 2 months the emergency brake Applied by itself. The second time it applied and then stalled. The dealership told me the first time couldn’t find an issue. It’s currently in the shop.
Hey guys,
A month ago I was driving in traffic at very low speed, pretty much bumper to bumper.
Suddenly the truck engine shuts off and the hazard lights came on by it self. I was not able to get it restarted immediately. All entertainment and lights were still working. there are no warning lights or anything. At the moment I thought it was my car sensor dirty that caused a emergency break, but it was clear and clean. After a couple of try the car restarted up and i was able to drive off.
Brought it to the dealership, they said there was no error code or anything so they are not able to help out. Called Ram Canada, wasnt able to get any help also..
Any chance anyone else has experienced this? or any other trouble shooting I can do to narrow down. This had never happened again since.
Ram 1500 Big Horn 2019 5.7
I have not experienced this, however, there is a recall on my 2022 1500 Limited for this exact issue. I'd definitely check into that first!
