TNRamGuy
So, I blow the pollen out of mine every time I wash it, 2 minutes, why not breathe?
Change once a year
Change once a year
Probably more like user error- there’s a lot of special people out there.Maybe some have had this issue, the CF11671 is what I use and have had no problems whatsoever. I guess its a roll of the dice?
Can't see why anyone would have a problem, I think that these are all the same? Anyone have any issues, take a photoProbably more like user error- there’s a lot of special people out there.
Haha, I get what you’re saying. There’s some people that have zero common sense. Pair that with zero mechanical aptitude, and you have things like this:Can't see why anyone would have a problem, I think that these are all the same? Anyone have any issues, take a photo
Judging by the reviewer's last name (pronounced holocaust??) I would agreeProbably more like user error- there’s a lot of special people out there.
Freshbreeze Carbon CF11671 will fit okay can buy it at Autozone....forgot the price but its cheap!Cant seem to find a filter replacement on amazon or autozone when I input 2020 model and see various sizes might be compatible. Anyone know of the real filter size I should be looking for on a 2020 build? not sure if limited means any difference in the size.
the 2019 and 2020 are the same...If you installed the k&n, can you tell me which part # for you? I have a 2020 bighorn and the VF2065 seems to work for the 2019 and I assume it will
Work for me also. That said, I saw somewhere on here where someone had an issue with it not being the exact right size. Thanks for any help you can share on this.
what is the part number? when I look i do not see one for the ram.I have a k&n cabin filter and i wash it every 3 months. It gets very dirty fast out here with pollen and sand and dust.
My bad I read this as FARM FRESH and was wondering what that would smell likeMopar part number is 68406048AA, not sure if they can reference it with stock part number.
Fram Fresh Breeze CF 11671 will fit too.
sorry posted the wrong one, here is for the in cabin air filterthat is the air filter
which I already have installed
thanks!sorry posted the wrong one, here is for the in cabin air filter
2019 Ram 15005.7L V8 Gas Cabin Air Filter
The K&N Lifetime Washable CABIN AIR FILTER for the 2019 Ram 1500 with a 5.7L V8 Gas engine is washable and reusable.www.knfilters.com
It's not so much breathing dirty air, as there really isn't a filter bypass when it gets dirty, but it can/will significantly effect your HVAC performance. If your A/C is subpar in the heat, or the heater is taking longer to warn the interior up, it's probably due to reduced airflow from a clogged cabin air filter.I have 121,000 miles on my 2017 and never changed the cabin air filter. Never really worried about it. Somehow I’m still alive from breathing dirty air.![]()
