CHMSL / Third Brake Light LEDs
Im just making sure I put the light back in correctly. There only seemed like there was one way to put it back in. Wanted to see if everyone elses looks like it.
Got it. I just replaced the LEDs on mine about an hour ago. Looks like yours, that’s why I wasn’t sure what I was supposed to see :)
Ok good! I guess I was thinking the top would have been more flush but I guess thats the design.
Do you have a link you could provide for both your bulbs?
JDM ASTAR Extremely Bright 2000 Lumens 360-Degree Shine 921 912 90-EX Chipsets LED Bulbs For Backup Reverse Lights, Xenon White https://www.amazon.com/dp/B01GGK6QDW/ref=cm_sw_r_cp_taa_Z5sJBbNN75AYP
LASFIT 912 921 T15 906 2835 W16W LED Light Bulb SMD 3030 Chipsets 1400 Lumens Extremely Bright for Car Center High Mount Stop Brake Lights, Brillant Red(Pack of 2) https://www.amazon.com/dp/B07CK1NQQ8/ref=cm_sw_r_cp_taa_o7sJBbBE8J4ZJ
Neurobit, I just replaced my lights. Looking at your pics, your housing looks to stick alittle out more at the top vs. my. Maybe the gasket were different, will have to wait and see if I have any leaks.
Could be. Someone else mentioned that my seal seemed thicker and wider than theirs. I did tighten it enough, but not too much torque since I did not want the acrylic to crack. It sits as it did before I took it off.
Damn doesn't ship to Canada.
Buy it, ship it to me and I'll repackage and ship to you. Did that with my buddy who lives in Cali and wanted an exhaust for his Harley. Company wouldn't ship to CA due to the strict emissions regulations. If there is a will, there is a way.
Makes me want to disassemble my factory bed lights and see if I can make them brighter.
Thanks for posting the links!! How do you like them? did they require a dealer flash code? Im looking to order these today if not.. trying to get all the cheap cosmetics done on my midnight 19'
You can try these. Will work for both brake light and cargo. I did mine week before last and it looks great. No codes generated, and about 8 bucks for a pkg of four.
http://a.co/d/dqBS9Ng
Here's a parallel thread:
https://5thgenrams.com/community/threads/rear-cab-lights-led.1662/
Cheers
On edit 09/12/19 - Can no longer recommend these. One started flickering after about 7 months. You get what you pay for. Go with Diode Dynamics of Vleds. Either will be magnitudes better than these cheap Chinese bulbs.
I love them! Cargo lights are bright. Red light is perfect. No flash or codes. Just plug and play.
Thanks for the offer. Found them on ebay instead of amazon and they ship to Canada.:)
Just installed these...thanks for the link. Will watch for codes, but I see none reported so far.
My one question: Those cargo LEDs sit pretty close to the lens. Any worries about heat damage from the LEDs at the tip of the bulbs?
I don't thinks so. All things being equal, they should be cooler than comparable incandescent bulbs.
As @Neurobit said you could run those LED's for hours and the heat they produce is minimal. You could touch them and they would be pretty well cool.
Fair enough! I have a lot of LED lighting (in the house and elsewhere), and it can't be assumed that they run cool. The transformers generate quite a bit of heat. Not halogen levels, of course.
