Chirp/Squeak from brand new Laramie Sport
Hello, I also had this chirping and checked for the noise in all areas of the vehicle just like in the video. After complaining to my dealer, who was aware of the issue from other customers, the guide plates for the brake pads were given as the reason. You would smear these with anti squeak paste and it would be good. I then picked the vehicle up from the dealer, but the chirping could still be heard.
I took a look at it myself at home and was able to fix it permanently. Nothing is defective, and no parts need to be replaced. The workshop just didn't find or look at the right places. I think some of the posts here feel the same way.
How to fix it, for me the noise was in the front: jack up, wheel down, push back the caliper carefully and slightly. Unscrew the two screws from the brake caliper. Remove the brake caliper and tie it up so that the brake line is not stressed. Carefully remove the brake pads. Carefully clean the guide plates used without bending them. You can also take them out, it's easier that way. If you look closely at the brake pads and the sheet metal, you will notice spots where the material has rubbed against each other. This is where the noise comes from. Unfortunately, the workshop applied anti-squeak paste, but did not find the right spots for the squeaking. Look closely at the pictures, then you can see the small shiny spots on the sheet metal, as well as on the edges of the pads. The silver paste is the work of the dealer, unfortunately I didn't take any pictures afterwards. I cleaned everything well and coated these areas with the well-tried copper paste. I've actually always done this with every brake service for 30 years. I'm surprised that everything is installed dry from the factory, which is why customers have problems with it. But go ahead, put everything back in place and enjoy the smooth ride. A job when the wheel is already dismantled, takes less than 5 minutes, costs a few cents for the copper paste. Maybe a modern brake anti-squeak paste would be better, I didn't have any on hand and the copper paste has always worked for me. By the way, if you can also do something to the spark plug thread when changing it, it can always be easily loosened, but that's another topic.
Greetings from Germany, I hope it helps you to fix the problem yourself or give the tip to the workshop instead of driving there 3x in vain and getting angry.
Does it bother you like it bother me!? Like, am I being unreasonable?
I can assure you that you are not being unreasonable. I didn't have this particular issue but the issue I had was treated the same way, "we acknowledge the issue but we don't have a fix for it". That's why I lemon-lawed it.
Before doing that though, I did take it to another dealer and they too said they couldn't provide a remedy. Maybe give that a try and hopefully you can get resolution.
Wow bro thank you so much
Hey bro just wanted to say thank you. Brought my truck to my personal mechanic and had him do exactly what you did. Chirp is gone!
Glad to see an awesome outcome!!! No not unreasonable to be mad. But they will not lemon law the truck because the dealer said they acknowledge it but cannot fix it! Even though the comment may not have been the best verbiage.
Mine did that for the first couple thousand miles, especially when it was cold out, haven’t heard it since
Update. Drove around town for a while and the chirp is back but luckily not as bad. Super annoying
Then maybe you have a job that was not good to see where it rubs overlook. I even made a little copper paste under the sheets before installation. Also inside where the brake pads in the groove are guided something. But the real noise comes from rubbing the sheets on the coverings. Too bad, looks again
I also have an issue with a chirp over bumps. Hard to tell where it is coming from.
Add me to the list. My 2022 Limited 2WD has the chirp on certain bumps (brick road not bad, but any recessed areas in the road I get the chirp.
Sounds like it is a brake clip issue. Interesting on the wire tie, however, mine is pretty distinct from the front left wheel. I get a clear listen of it from my driver’s seat.
Has anyone had luck with a dealer acknowledging the issue? I plan to have them take a look at first oil change. I’m at a 1,000 miles now.
For those who say it is a brake clip issue, how can you tell…is it louder with the window down? My chirp is louder with the windows closed, so I assume it is not a brake clip?
Have you all checked the driver’s side wiper arm? Mine was chirping over sharp bumps, and when I pulled it back and forth, I noticed a little play in the arm and it made the same chirping noise.
I took the lock but off with a 5/8 socket and sprayed a bunch of PB lubricant. Then I ran the wipers so the lubricant spread around. The chirp was gone.
There are a couple of chirps on these trucks, so this one was mine. You may have a different one.
My annoying chirping was also the brake pad clips.
I had been suffering from it since about 15k mi and now at 30k mi. 2023 Ram Rebel non air.
I didn’t disassemble the caliper as suggested by others since I was doing a quick troubleshooting session. I sprayed in between the cracks with cleaner and then lube. Chirp has gone anway completely although I’m thinking it’ll be back in a few weeks. I’ll try to have the dealer or myself disassemble and lube properly.
Here’s the official bulletin which was also posted in this thread or somewhere else.
It will 💯 come back unless you do the more permanent grease or some other fix. Rain or water will wash away your temp fix. I went through this a couple years ago. I would lube myself with silicone spray which fixed it but it would return after a good wet road drive. Finally the dealer recreated it and they fixed it by replacing my brake pads and I think did the lube fix. Mine have been silent ever since.
I have 2025 Tradesman, and it's doing the same thing when I break at slow speeds. At first, I thought it was due to a leveling kit and the 33s. I guess I'm not the only one with this issue.
Mine started doing this about a month back, on the right side.
My wife was picking me up and as she drove up I heard what sounded like maybe a stick was stuck in between the rotor and the dust shield, but it was intermittent.
Fast foward to last week when I picked it up from the dealer and they said they heard the sqeek and said it was the upper control arm, and they lubed it but it may still needed replacement maybe. The UCA are Rough Country.
Then just the other day I had the tires rotated, I heard it as the tech was pulling it into the garage turning left and I heard it, a constant squeek, like a break pad wear indicator.
Today I drove with the window down and I could hear it. It sounds like a bird chirping, and didnt seem to change much with speed or turning....
