WRH
- Jul 11, 2018
Nice Install. Just got done with my install in my Big Horn.
I only removed the cargo divider that flips up and down. I didn't even remove the rubber mat nor the side clips, because I test fit mine and my slider worked perfectly. I got the regular, dial lock version - so I'm assuming your fancy lock is just a little bit more proud and would require the mat cutting. Total install time was 10 minutes and that includes resetting the combination.
I really love this safe and Lock'er down customer service has been fantastic. It's a bummer that there are different clearances with the limited models, but that's the growing pains of a next gen vehicle. I'd argue lock'er down did a fantastic job of handling the issue thus far.
I wish I had seen this tip before fussing with those damn tabs. Tried to do it carefully, then finally just twisted them with pliers until they popped off. Glad I saw it before I cut my map though! Great tip! For anyone else doing this, I'd highly suggest going this route before breaking the taps and cutting your mat.
