theblet
- Feb 8, 2021
Yes I know lolm
Direct drive. No gears.![]()
Yes I know lolm
They are just crippled by everything elseElectric motors not crippled by connecting rods and valve train, they are probably running more like 6.13's.![]()
Cybertruck has a nice big bed for your extension cord. Just play it out as you go and no worry about running out of charge.They are just crippled by everything else
The cord and the generator?Cybertruck has a nice big bed for your extension cord. Just play it out as you go and no worry about running out of charge.![]()
Need to carry lots of gas for the generator also.The cord and the generator?![]()
Nah, leave the generator running in your driveway and use long extension cord. Hurts efficiency too much to tow generator around all the time, only tow it to the truck stop when it needs refueled.The cord and the generator?![]()
In summery, just fill it up & drive ur truck.Huh?
What’s tow haul change then in both comparatively? That’s what should be compared for towing not regular drive and over driveI hope this post will help to end the debate with facts and not opinions, and become THE post people refer to those who are having a hard time deciding.
You already know that 3.92 is better for towing, and 3.21 gets better fuel economy, so I will talk about what you might not know
Bottom line up front:
In layman's terms, to conceptualize the difference, imagine
1) 5 out the of 8 gears have the same final drive ratio between 3.21 and 3.92.
2) 3.21 has "an extra" overdrive gear.
3) 3.21 has 2 unique lower gears for towing.
4) 3.92 has 3 unique lower gears for towing.
5) Speed range that 3.21 is better at towing: 31-38 MPH, 48-57 MPH.
6) Speed range that 3.92 is better at towing: 0-30 MPH, 39-47MPH, 58-70 MPH.
Explanation
1) 5 out the of 8 gears have the same final drive ratio between 3.21 and 3.92:
Here's the gear ratio for the 8 speed transmission:
1) 4.71:1 2) 3.14:1 3) 2.10:1 4) 1.67:1 5) 1.29:1 6) 1.00:1 7) 0.84:1 8) 0.67:1 Reverse) 3.30:1
Final drive ratios with 3.21
1st. 15.12, 2nd. 10.10, 3rd. 6.74, 4th. 5.36, 5th. 4.14, 6th. 3.21, 7th. 2.70, 8th. 2.15, R 10.6
Final drive ratios with 3.92
1st. 18.46, 2nd. 12.31, 3rd. 8.23, 4th. 6.55, 5th. 5.06, 6th. 3.92, 7th. 3.29, 8th. 2.62, R 12.94
From the list below, we can see that gears 3-7 in 3.21 matches gears 4-8 in 3.92:
-- NO MATCH -- = 18.46 - 1st - 3.92
3.21 - 1st - 15.12 = -- NO MATCH --
-- NO MATCH -- = 12.31 - 2nd - 3.92
3.21 - 2nd - 10.1 = -- NO MATCH --
-- NO MATCH -- = 8.23 - 3rd - 3.92
3.21 - 3rd - 6.74 = 6.55 - 4th - 3.92
3.21 - 4th - 5.36 = 5.06 - 5th - 3.92
3.21 - 5th - 4.14 = 3.92 - 6th - 3.92
3.21 - 6th - 3.21 = 3.29 - 7th - 3.92
3.21 - 7th - 2.70 = 2.62 - 8th - 3.92
3.21 - 8th - 2.15 = -- NO MATCH --
2) 3.21 has "an extra" overdrive gear:
The 8th gear in 3.92 is the 7th gear in 3.21, thus effectively mean the 8th gear in the 3.21 is an extra gear to the 3.92.
Meaning, when you go test drive the 3.21 you will have to downshift to 7th to get the same acceleration at 3.92's 8th on freeways. That is why some people complain about how "sloppy" the 3.21 is, because the 3.21 has an extra overdrive gear for fuel economy. If you shift 3.21 in 7th gear, you will get the same acceleration as the 3.92 in 8th on the freeway. No, 3.21 isn't sloppy, you're just in a gear that 3.92 does not have.
3) 3.21 has 2 unique lower gears for towing:
As we know from 1), 5 gears have the same final drive ratio.
You "gain" an overdrive gear, but you "lose" one towing gear.
Here's the final drive ratio for the 2 towing gears.
4) 3.92 has 3 unique lower gears for towing:
Same logic as the last
Final drive for 3 towing gears.
1st. 18.46, 2nd. 12.31, 3rd. 8.23.
5) Speed range where 3.21 is better at towing: 31-38 MPH, 48-57 MPH,
AND
6) Speed range where 3.92 is better at towing: 0-30 MPH, 39-47MPH, 58-70 MPH:
Calculated towing shift point to be 6000 rpm, if I'm off the logic is the same but the speed will vary.
For towing,
From the speed 0-30 MPH, 3.92 has higher final drive ratio over 3.21 (18.46 vs 15.12) until it has to shift to 2nd gear at 30MPH.
From the speed 31-38 MPH, 3.21 has higher final drive ratio over 3.92 (15.12 vs 12.31) until it has to shift to 2nd gear at 38MPH.
From the speed 39-47 MPH, 3.92 has higher final drive ratio over 3.21 (12.31 vs 10.10) until it has to shift to 3rd gear at 47 MPH.
From the speed 48-57 MPH, 3.21 has higher final drive ratio over 3.92 (10.10 vs 8.23) until it has to shift to 3rd gear at 57 MPH.
From the speed 58-70 MPH, 3.92 has higher final drive ratio over 3.21 (8.23 vs 6.74) until it has to shift to 4th gear at 70 MPH.
The key takeaway here is that towing heavier trailers uphill with 3.21 might never reach the desired speed within the 58-70 MPH range (typical highway towing speed) because 3.21 jumps from 10.10 to 6.74 without the 8.23 final drive ratio found in 3.92 that really help maintaining highway towing speed at max load.
Do you value the "extra" overdrive gear for fuel economy? or do you value the extra towing capability that you tell yourself you might one day need? That's up to you.
We all agree that 3.21 gears will get better mileage on the highway than 3.92, right? But why exactly?
Well, a taller tire just slightly raises (numerically lowers) your gearing. Your crankshaft turns less RPMs for every mile driven.
... since lowering your speed/RPM whilst in high gear makes such a large impact on MPG, it stands to reason that the higher "effective ratio" of taller tires should theoretically improve efficiency at a particular speed on the highway.
Interesting... thank you.True, but so what? You didn't quite answer your own question so ...
1) Pumping loss. Your engine is actually using some power to create a vacuum in the intake. Heavy throttle opening at low RPM is relatively more efficient than light throttle at high RPM.
2) Friction. At least to a first order approximation, friction is proportional to speed, and for whatever reasons, car and truck engines are built with sleeve bearing technology that has seen only marginal improvement in millennia. In spite of the fact that just about every other rotating part of the vehicle has ball or roller bearings. Motorcycle and marine outboard motors are routinely built with roller bearings. Go figure.
I wouldn't characterize it as a large impact. To a first order approximation, It still takes a certain amount of fuel to be burned to accelerate a couple tons and maintain speed against air resistance. Marginal improvements come from burning that fuel more efficiently.
In my own unscientific, non-double-blind testing, the difference between 6th, 7th, and 8th gear at a fixed speed on the same stretch of level road falls out to be about 20, 19, and 18 MPG respectively. Tire size achieves basically the same thing.
- EXCEPT -
Taller tires will hurt aerodynamics, letting more air pass under the truck, creating turbulence and drag. You could offset this by lowering the suspension to cancel out tire size.
Just stuff for discussion...
Back on the gear ratio topic:
If you changed to taller tires but did NOT correct the calibration of your speedometer, then consider this:
If larger tires slowed down your speedometer then it also slowed down your odometer by the same percentage.
If 70 MPH on the speedo is really 75 MPH on the road then you have gone more than 1 mile when the odometer registers 1 mile.
You are getting more miles out of every full tank of fuel than what you are being shown on the dash.
Therefore your calculated mileage, be it on the dash or hand calculated, is now showing less than the true MPG that you are achieving.
Of course, this does NOT take into account the increased rotational mass or unsprung weight... but since lowering your speed/RPM whilst in high gear makes such a large impact on MPG, it stands to reason that the higher "effective ratio" of taller tires should theoretically improve efficiency at a particular speed on the highway.
Albeit, so long as you are below the threshold of diminishing returns from the increased wind resistance load or at an RPM to far below peak torque (volumetric efficiency) of the engine.
By "6th, 7th, and 8th gear at a fixed speed on the same stretch of level road falls out to be about 20, 19, and 18 MPG respectively."
What speed were you maintaining? Was it the same speed in all gear ratios? Are you basing this on the mileage/vacuum gauge in the cluster?
Clearly, better MPG can be attained by driving at 45 MPH than will be attained at 65 MPH. (I'm kinda assuming that is because load & drag increase exponentially?)
What we need is an engine that can run at high RPM but low load in a very lean condition. Sipping on fuel and creating good power. But then we need to strangle it with emissions equipment and EGR’s. Ahhh that would be a dream. (Please note the sarcasm here)Simple arithmetic:
>Large displacement engine + >more RPMs per mile = more fuel burned.
