You guys really believe that engine rpm is the key to milage? My 4000 lb car has a 6.4l, bigger cam, runs 500 rpm higher than my little 5.7l truck. The car gets 4 mpg better. Why? It does not work as hard at a higher rpm to move. Kind of like the truck with proper 3.92 gears as opposed to the truck with underpowered 3.21 gears lugging along. It's not all about rpm. If it were the 6.4 spinning faster would burn more fuel.
Not the whole key, but a significant factor. Your car probably has much better aerodynamics, so apples and oranges.
But comparing different drive ratios (which includes tire size) for otherwise equal vehicles, I would expect lower RPM to be more efficient. I don't have a fuel consumption map specific to our 5.7, if anyone does I would love to have a copy, but a typical ICE efficiency "sweet spot" might be around 1200 RPM at 3/4 throttle. Lighter throttle causes more pumping loss, higher RPM more friction. My $.02.
