theblet
- Feb 8, 2021
Well, I’ll get two then!Yes….of course. My butt dyno shows at least 50 hp. Compensates for not having 3.92’s.![]()
I think the 3.21 grocery getter truck requires lavender and lilac oil doesn't it?What kind of oil do you recommend for the 3.92? Is it different than for the 3.21's? I think I remember reading something about using boutique oil will help compensate for getting the wrong gearing.
What's worse, is you're debating this at 3:17AM...LOLI think the 3.21 grocery getter truck requires lavender and lilac oil doesn't it?
But only if it is sustainable, responsibly harvested, organic lilac. The lavender should be pollinated by biodiverse bees!I think the 3.21 grocery getter truck requires lavender and lilac oil doesn't it?
Peppermint oilI think the 3.21 grocery getter truck requires lavender and lilac oil doesn't it?
On purpose?Got my 2022 with 3.21.
4:17 eastern time. I got up a little late. I promise I will be quicker to the draw next time!What's worse, is you're debating this at 3:17AM...LOL
On purpose?
4.17? That’s the gears my truck has. Guess my build sheet is wrong.4:17 eastern time. I got up a little late. I promise I will be quicker to the draw next time!![]()
Hey, at least you picked the right truck this time.Yes. Drove the same trucks with the 3.21 and 3.92. Chose the 3.21 because I do not tow more than 4000 pounds.
My new Ram is also 325 pounds lighter than my old Ford F150, with 35 more hp and 8 speeds versus 6. It's a lot faster and gets better gas mileage than my Ford with the 5.0 V8.
I'll probably be in a 3500 when they redesign them. Hopefully they put something like I wanted together.Last, I hope you find your dream truck with the brown/beige interior you prefer.
C'mon @Mountain Whiskey, your slow response is making the 3.92 guys look bad4:17 eastern time. I got up a little late. I promise I will be quicker to the draw next time!![]()
I think his Circadian rhythm is offC'mon @Mountain Whiskey, your slow response is making the 3.92 guys look bad![]()
It's the time warp thing from the 3.92 speed. It's hard to align the curve. There's a wormhole effect.I think his Circadian rhythm is off![]()
Good thing your truck only weighs like 4k lbs.
Guess you'll have to change out the diff after towing that Z06.
Nah, I'll just throw the truck awayGuess you'll have to change out the diff after towing that Z06.![]()
