rsonedecker
- Dec 12, 2018
So I started the speaker replacement a few days ago.
I have the 10 speaker alpine.
First test was a baseline Speaker Pop polarity test with ANC "on" (as it is from the factory). I tested using an aux cable plugged between the phone and the radio, with mono test signal output turned on and playing the test "pop" through the aux media source on the radio, with the volume turned up. Signal strength was excellent, and it's very accurate this way.
Every single speaker EXCEPT for the left dash speaker was out-of-phase. Center, right dash, all doors, and both rear upper speakers were out-of-phase. And my left dash speaker was NOTICEABLY louder/brighter than all the rest, and I had to have it faded way to the right-rear to get decent balance.
Next, I disabled ANC - (removed both positive and negative microphone wires from the amp - chose to do all 8 just to be "thorough").
Tested again, and disabling ANC changed nothing, all the speakers EXCEPT for the driver(left) dash were still out-of-phase. So doesn't look like ANC is causing the polarity change.
I then validated all the wiring at the amp, and that it matched the wiring diagrams. (except the Crank RPM wires, which were reversed in the wiring harness, BR/DG was in position 6 instead of 1, and BR/GR was in position 1 instead of 6)
So then I replaced all the dash speakers yesterday. All the dash speakers are the same part number, and the positive terminal is the left terminal (when holding the speaker upright (cone facing upward) and looking at the plug) - I tested all of them with the 9 volt test to verify polarity.
For the left front dash, which was in-phase, the factory harness plug has the GY/YE wire in the positive position (what would connect to the positive terminal of the speaker), and this wire IS carrying the positive signal. The Wiring Diagram indicates that it's supposed to be negative (but it's positive). The GY/OR wire, which is supposed to be positive, was in-turn negative. The wiring diagram is incorrect for the left front dash speaker (or the amp is configured incorrectly, or there is a sub-connector in-line on the harness somewhere and that is reversed). Since the wire carrying the positive signal was in the correct position in the factory harness plug, I did not need to re-pin the Metra Harness at this location.
However, the wiring at the center and right dash speaker was incorrectly pinned at the factory - the positive wire indicated on the wiring diagram (GY/DG - center, and GY/BR - right) WAS indeed carrying the positive signal (wiring diagram was correct), but it was connected to the NEGATIVE terminal on the factory speaker (causing the out-of-phase issue) - it was in the right (not left) position in the factory harness plug, but it should have been in the left position. I therefore re-pinned the factory harness plugs (much easier than the metra harnesses) and switched the positions in the harness plug at both the center and right locations.
Installed all three GX302s and they are now all in-phase, and the sound is much more balanced across the front, and the "surround sound" sound field works so much better now.
I left ANC disabled.
More to come (more speakers to install!)
I know there are some people that think this is not a "mistake" but based on the variable nature of other people's problems (sometimes it's just left door speakers or just the right, sometimes only one dash and all doors, sometimes various doors, etc - in other words, random), I personally feel these issues are mistakes and not supposed to be this way.
