rsonedecker
- Dec 12, 2018
And in addition, many metra harneses have "reversed" versions, and I actually just ordered some because of the situation I am faced with at the doors. I had purchased the 72-6514 71-050 harnesses, which position the positive wire correctly in relation to the factory plug and speaker, but taking into consideration the post above, instead of re-pinning the factory plug, I think I'm going to flip polarity using the Metra harness - so I just ordered the 72-6514 71-050 which is the "reverse" version of 72-6514 71-050.
Edited above because I had them flipped.
And in fact, I've brought this up before - there are FCA speakers that use the same plug, but have different polarities (hense the need for metra harnesses that plug into the same plug, but have flipped wires - like the pair above). Could the wrong speakers be getting into our trucks?
Reason being is that I just popped open the driver's side front door, and that factory plug is reversed as well - the factory positive wire which is indeed carrying the positive signal, is located in the negative position in the plug (which is causing the door speaker to be out-of-phase). So again, here we are seeing polarity being changed AT THE SPEAKER instead of at the amp where you would think if it was meant to be happening, it would happen there at the amp - not at the speaker.
I expect the other doors to be same.
