Fan speed, temperature, and recirculate are all different options. Automatic mode determines what to use, but you can set recirculate independently of auto mode. You could easily design the software to turn off recirculate if the interior temperature is higher than the exterior temperature. Once they swap, you could turn recirculate back on. This would probably be the most efficient way to cool the cabin down. I don’t know for sure if that is what RAM is doing, but I do know that I had recirculate turned on in my truck yesterday when I drove it, but today when I remote started it out in the sun and got inside, recirculate was turned off. So, that means they either are intelligently deciding whether or not to keep recirculate turned on during a remote start, or it was just a software glitch and didn’t remember my previous settings - there have been plenty of times I've gotten into the truck and recirculate was kept on as I previously set it.
Yes, I have the panoramic sunroof. And like I mentioned, I’ve had panoramic, and even a full glass roof on several other vehicles and never had any issues like this. The sunroof is not the problem. It’s the poor performance of the air conditioning.
I’m pretty sure if there’s an identifiable issue, a TSB will come out addressing it. But that doesn’t excuse the fact that this issue has come up, and they didn’t catch it in testing, and that buyers have to deal with it until it's fixed. I don’t think there’s much competition with the new Silverado’s though. Their interior is hilariously bad compared to the new RAM.
It does come tinted from the factory, just not to an extreme level. I think this is good because you have the sunshade there as well if you want darkness, but if you actually want some light to enter the cabin without opening the sunroof, you have that option as well. I find it hard to believe that the sunroof wouldn’t come with some pretty decent heat rejection properties from the factory, but augmenting it with aftermarket window tint should certainly make some difference.
