alacombe
- Apr 15, 2018
Nope, I have none. Truck is great so far.Yep! No complaints with my Ram. You?
Saw a video on the 1234yf yesterday and apparently it is quite flamable as compared to the previous generation. They had to do special testing which showed that under the right conditions it could be hazardous. I am no genius on the matter but it may be of interest. I would post the link here but the video contains a few words some may find crude or offensive so I will only provide it if Jared B approves.
Here is the difference between drivers side and passenger side yesterday...8 degree difference.
This is still not as good as my 2017 BMW's A/C.
Vent temp will increase the further away from the evaporator the vent is. The far right vent may be the coldest or slightly warmer than the right center and the far left the warmest typically.
Interesting article about the refrigerant, there are similar concerns over rigid foam insulation in our walls when combusted, which is why I chose not to use it in my camper - truly deadly fumes when burned, ask a chemist. I would say the idea that the EPA will help regulate a corporation’s actions (such as use of this refrigerant) under the current administration is very unlikely - not meant to be political or polarizing, but reasonable observers would likely agree. If as consumers we are not satisfied with this refigerant due to crash safety concerns (remember the exploding Pinto and the $1 fix Ford refused to install until forced?) our feasible avenues are therefore either customer care (not likely to help on this), online criticisms comparing to their direct competitors threatening the brand’s safety image, or litigation, at least until the administration’s view of the EPA’s role changes. No great options if regulators can’t help us.I was doing some research on the new refrigerant in our trucks and look what I found. Ram should be ashamed, Mercedes refuse it because of fire hazards. The EPA must have FCA in their back pockets, if the EPA says jump FCA says how high. Politicing to the Fullest Excuse my Grammar
http://www.dailymail.co.uk/news/art...-caused-ENGINE-FIRES-Mercedes-Benz-tests.html
I am providing links to 2 videos on 1234yf. The first link is based on a Daimler Benz investigation and the second is a video by an Australian auto expert who uses an ocassional crude or offensive word so open at your own discretion. I found both to be very informative. The Aussie also posted a very good video on window tint and what it really does and doesn't do. I will post that in the tint discussion.Sounds like an informative video, go for it. Maybe just mention its not safe for work or something in case someone opens it at their place of business.![]()
The window tint video actually addresses the interior cooling issue as well. Once again, be aware that a few words may be considered crude or offensive to some.Sounds like an informative video, go for it. Maybe just mention its not safe for work or something in case someone opens it at their place of business.![]()
So curiosity has gotten the best of me, back story here - 20yrs ago I used to work apartment maintenance and have my EPA lifetime license for "Universal" meaning Home, and Refrigeration and "Auto" which used to be R-12. While Refrigerant and technology has changed the rules haven't.
A/C 101 -
all Refrigerants work on the same principle amount of pressure effects temp
Every wonder why your home a/c freezes up? 1 of 2 reasons:
1 - dirty filter not enough airflow over the coils
2 - Low pressure, thus the need and market for a "a/c tuneup" or "top off"
If your "freon" pressure is too low it drops below freezing and you coils ice over!
There's a balance between too low of pressure and too high and it is affected by ambient temp, we all learned in science class that heat causes gas to expand right?
Now here's the info...
I couldn't find a whole lot of info on the R1234yf everything is still mainstreamed for R134a however they both operate at close to the same pressures so here's what it boils down to:
Depending on outside temp it should be running between 36.5-55 psi on a set of gauges for the low side.
36.5 would make R1234yf 38 degrees F @ 65F ambient temp
55.0 would make R1234yf 56 degrees F @ 85F-110F ambient temp
I no longer do a/c work and don't have the gauges to hookup to my truck;
but if I was servicing it myself I would want mine to run @50 psi on these hot days giving me a 50 degree F temp
I've attached my own excel chart in pdf since I can't upload an excel doc and here's the references:
https://www.tecumseh.com/~/media/No...ica-Library/ES114-TempPress-Card-AE2-1114.pdf
http://rechargeac.com/how-to/ac-system-pressure-chart
https://www.arcltd.org.au/media/1040/auto-gas-booklet.pdf
and lastly, regarding the flammability of R1234yf I can't find the link to where I read it, but the conclusion was that it was no more a risk than having fuel under the hood. If you want no risks, lock yourself in your house and pray you don't get hit with floods, lightning, tornados, wildfires or earth quakes, and for my friends in Florida sinkholes!
You forgot hurricanes and aliens.So curiosity has gotten the best of me, back story here - 20yrs ago I used to work apartment maintenance and have my EPA lifetime license for "Universal" meaning Home, and Refrigeration and "Auto" which used to be R-12. While Refrigerant and technology has changed the rules haven't.
A/C 101 -
Hmm I figured floods and tornados covered hurricanes but I definately forgot the aliens and zombies!You forgot hurricanes and aliens.
