Air conditioning Hack
U
User_3336
Guest
Had to be a TSB, but I haven't seen one stated.
QUOTE="wallyuwl, post: 334922, member: 32026"]
Did they say exactly what they did or how they reprogrammed the blend doors?
[/QUOTE]
PMantle
So, sorry if this has been covered, but anyone know about how many turns are needed to get the valve open enough for a little higher temps? Full blast cold is too cold when it's not so hot out.
brian42
San Diego, CA
I think that's going to be a personal preference set through trial and error. Too many variables (personal preference, weather conditions like temp/humidity/clouds/climate, etc.) play into that.
On my last truck it was a constant struggle to get it cold enough for me but warm enough for my wife.
dts828
Atlanta, GA
So true don't here in GA, I tried going about 90% open because some nights when I get off work I could use some warm air either for defrost or just heat. Unfortunately the 90% valve open position made a noticeable difference in cold temps during the day. In my case I need it 100% open.
wallyuwl
@RamCares just advised me via private message that Ram will be releasing something in Q4 of 2020 to address this issue. They should be announcing it shortly. Fingers crossed...
Did they say if it will be a technical service bulletin? I plan to buy an August build 2020 tomorrow.
PostPremium
Unfortunately he will learn a lesson. No good deed goes unpunished.
I sure hope Ram doesn't consider relaying requested information during a customer service interaction a good deed. That attitude would only serve to erode their recent successes. Nah, they couldn't be that clueless.
RamCares
Michigan
grooves12
@RamCares are you maintaining a list of people waiting on this fix? If so, count me in.
I am going to be scheduling regular maintenance this week. Should I bother bringing it up to my service agent or should I wait until the fix is rolled out?
Techguy2000
Dallas, Tx
I would wait and see what the results of the TSB are, plus it's winter so it'll be hard to compare results to the dozens of people who have posted vent temps when it's 90F+ outside. If the AC cooling isn't really bothering you I'd wait until end of next Summer to look for performance of the TSB, complaints of rattles in the dash, scratches left by techs, etc.
I want a meat locker like the rest of you but to me this is worth waiting a while. My truck won't be the one the techs learn with lol
brian42
San Diego, CA
I'd love to wait until next summer but I've got 35,450 miles on the odometer so I've got one last chance for "free" repairs under my basic warranty.
I've got an appointment next week and I guesstimate that I'll be dropping it off with not much more than 100 miles left on the B2B.
Hopefully I can convince them to do the repair.
Scram1500
Much like any operation I want to know the risks before hand, how invasive is the procedure? I can deal with sub par AC or the hack if it means avoiding my dash being torn apart
PostPremium
If the inadequate temps are due to heater core design, then it should be easily reproduceable regardless of outside temps. I hope this is the fix we've been waiting for.
