NoThisIsPatrick
- Jan 22, 2025
Following this thread as I’d like to add passive entry to my 2025 Big Horn. Hopefully we have a solution soon!
Definitely be a new thread (there actually needs to be an entire new 2025+ section), very different install.hmmm, Im guessing some of the process would be the same but I wonder it adding it to a 25 should be a whole new thread since it is a completely different electrical architecture and going to be completely different part #s
Is the future looking bright for us folks wanting to add this soon?Definitely be a new thread (there actually needs to be an entire new 2025+ section), very different install.
Not yetIs the future looking bright for us folks wanting to add this soon?
They probably took the work done on here to make their kit. Just like they did with UC4 to UC5 upgrade. This whole thread on here shows how to do it on the 2019 to 2024. And it's a lot cheaper.Did you guys see this thread for 2019-2024?
Looks much easier.
We’ve built something special just for your Ram 1500 DT. After rigorous R&D, we’re excited to introduce the Factory OEM Mopar Passive Keyless Entry Upgrade—a plug-and-play solution designed specifically for your truck.
No more fumbling for keys when your hands are full. With one quick touch, your Ram unlocks effortlessly, keeping up with both your lifestyle and your expectations.
Dealers may have told you that you’d need to buy a newer trim or settle for a clunky aftermarket solution. But you don’t need compromises, and neither does your truck. With our OEM...
- Infotainment
- infotainment mopar oem passive entry ram 1500
- Forum: Infotainment.com
Do you have a SGW bypass installed?Just tried updating my BCM in my 2024 Big Horn but the AlfaOBD wouldn’t connect. Not entirely sure which option to select so I choose the very bottom one labeled simply “Body Control Module.” Am I wrong in doing so? Just spent close to $1,500 in parts, labor and the app to have normal function door handles.
Yes. Using a 12 + 8 pin connector.Do you have a SGW bypass installed?
Are you hitting the Bluetooth icon in alfaObd to connect to the Bluetooth adapter? I got frustrated a couple weeks ago, after buying a new Bluetooth adapter, because it wouldn't connect. I had forgot to actually connect to the adapter within the alfaObd appYes. Using a 12 + 8 pin connector.
Yes.Do you have a SGW bypass installed?
Yeah, I ended up emailing the app admin and asking about which option to choose for the BCM. Got everything squared away but it’s not coming up it settings yet. I know I saw a few people run into similar problems in this thread so I’ll go back and find the solution. Thank you sir!Are you hitting the Bluetooth icon in alfaObd to connect to the Bluetooth adapter? I got frustrated a couple weeks ago, after buying a new Bluetooth adapter, because it wouldn't connect. I had forgot to actually connect to the adapter within the alfaObd app
Thanks. I've communicated with Jimmy. He told me it would be cheaper to buy the OEM than for him to make one with both options. I'm just trying to figure our what LEV sales code is; and if I need it.you can get the passive entry harness from Jimmy07, but not sure about anybody making one for the ambient lighting. You might have to buy oem for that or do the research to make our own. However if you were to buy a new oem harness might as well get one that has the passive entry and the ambient lighting.
So is this just basically a bundle with the two door harnesses (which can be sourced from Jimmy), bypass wires, and an alfaOBD (which can be sourced on Amazon)?Did you guys see this thread for 2019-2024?
Looks much easier.
- Infotainment
Yes, pay infotainment 229 for cables and coder or jimmy for wires and amazon for coder for less. Or follow the thread and make you own wires. I would make my own or buy from jimmy and amazon, paying extra just so you only have one order is what infotainment offers not for me but 2 people liked it so for each there own. Plus love that everyone here put this together so I rather reward there effortsSo is this just basically a bundle with the two door harnesses (which can be sourced from Jimmy), bypass wires, and an alfaOBD (which can be sourced on Amazon)?
No knock on infotainment, I can see the appeal for some for the "easy" obd program but I also want to be able to do other things with the alfaobd.Yes, pay infotainment 229 for cables and coder or jimmy for wires and amazon for coder for less. Or follow the thread and make you own wires. I would make my own or buy from jimmy and amazon, paying extra just so you only have one order is what infotainment offers not for me but 2 people liked it so for each there own. Plus love that everyone here put this together so I rather reward there efforts
