Nieto91
- Dec 30, 2021
Jimmy07Where did you get the connector from or what did I need make the connecter
I just got done putting a 12" in my big horn. was not a hard job. you must follow instructions word by word. Now that it is in, it is very enjoyable. Went from a limited to a big horn and now trying to put a few luxury items in the big horn.Has anyone done this successfully yet?
Just a recap on the info we have here to make the conversion from 8.1 NON Nav to 12.1 Nav:
Rewire cable with blue tape to match 19RamLimited Picture
get cable to override 911 message: https://www.infotainment.com/products/911-vehicle-phone-override-cable
get LVDS Cable: https://www.factoryradioparts.com/p...e-differential-signal-jumper-cable-05064684ad
get Radio Module: 68317978AI
get 4c Uconnect Navi 12.1 screen.
Is this accurate to make a FULL conversion? or am I missing something?
So far it has been the most stable the radio has ever been both CarPlay and Android Auto work flawlessly. The update also allows Off Road and Performance pages. Still tinkering with the pages though. That being said this is a retrofit and SiriusXM Guardian does not work anyway.
I think the sensor is only in the off road package, mine does not work either.finally had a chance to get the performance pages turned on. Everything seems to work except the g-forces and pitch &roll never moves always at zero. Anyone else have this? I would think the vehicle has a yaw rate sensor in it somewhere. 2019 ram limited.
This is what you want to look for. The application file will be updated.On my 2019 the current software version is: 21.32.14
Hardware part number is: CNSC28NOGL
1- Can this be updated to 39.7?
2- Install 34.2 first and then 39.7?
3- Has anyone with the same hardware version done it successfully?
My factory warranty just ended, dont want to risk turning the unit in to a brick!
No need to update then, you have the newest version.I have the same application # that is on your pic.
So, it is OK?
Thanks
You need version 39.7.0 and AlfaOBD to turn them on.OK -- so my truck is not capable of displaying off-road pages?
that is the only reason I was looking at the 39.4 update
thanks
Yes, I did, and working absolutely error free.Hey has anyone here installed a 12” display in a ram 1500 bighorn 2019 ? Had some questions lmk thx.
