Click on both of those app at the same time for like a couple of sec and it takes you to dealer thing
OK, I know it's nit-picking, but you are only actually pressing the two lower extreme corners of the screen, you can press just enough of it without touching the app icons.
Can I install this firmware for EU version truck 2019? Very want Performance and offroad pages.
Отправлено с моего iPhone используя Tapatalk
probably not, I think it includes software updates for cellphone modem, nav and other stuff which maybe different in Europe.
How do I get pitch and roll to work? Just stays centered at 0. Thanks
Sorry, I want to update my radio, where are the files to download?
I have my 2021 Ram Rebel that I did the 12" upgrade, It currently has PR39.6
Can I do PR39.7 update to this unit and gain the performance pages ? I have OBD JScan will I be able to change it with JScan or do I need AlfaOBD ?
Any other info would be great Thanks!
Yes. I did in my 21 bighorn with the same version of what you have. Not sure if Jscan works, I used AlfaObd
download the file but it says files not supported
You can't put the files in the root of the USB, have to put the VP4R_Update folder with the files in it at the root.
Don't skip any versions. If you're at below the 34.2, do that one first.
Does the 8.4 support performance pages?
Does anyone have a complete list of parts/tools (with part #'s if possible) of what I will need to take my 2021 Ram 2500 Laramie diesel , non nav 8.4 screen, to 12in screen. From what I have researched, there seems to be a difference in part #'s for 12in screens for 1500 vs 2500 trucks. So far, I think I need a Security Gateway Module Bypass from Kaodtech, to bypass gateway behind instrument cluster, a OBDLink MX+ reader, a custom wiring harness (not sure where to get), a LVDS Cable (not sure where or what to get), a 12in center stack screen, radio module, and radio module mounting hardware. I am unsure of a lot of part numbers since it is a 2500 truck. Any help would be appreciated.
This was what I used 0735C9A0-31B5-43B8-A2C6-C8D53D98DDDC.pngAB9BDCD9-B609-4E83-8CE5-B716728006F9.jpeg0A39521C-140B-4630-A581-7E638E9FA033.jpeg6CCFC0EB-93D7-420A-84FC-D27E5F06ED2B.jpeg441E99C6-BFDE-4212-B1FA-4D360E4F4AB7.jpegE5B42BF3-8FD8-47A5-91A4-62A31CBA001B.pngOn a 2021 Ram 1500
And jimmy07 can do the wire by pass
Okay, this helps. And you were able to get this done on 2021 2500 ram? Did you have to take the gauge cluster out out in order to do the bypass?
