mikehillmt
- Nov 16, 2019
The PAC AP4-CH41 (R.2) picks up the source signal before the HK amplifier / processor. The advantage on doing so is: 1. you get a cleaner non processed signal, 2. the PAC output channels does bypass the Active Noise Cancellation that is processed by the Harman Kardon / Chrysler amplifier.
I have already installed a sub (SA-12 D2 REV.3- Sundown Audio 12" 750W Dual 2-Ohm SA Series Subwoofer) and amp (Sundown Audio SAE-1000d v2 SAE Series 1000W RMS Mono Amplifier). As you know, tapping the bass from the DSP of the HK amp at the point of the ANC is amplifying the hell out of the ANC anti-humm from my oversized tires. Before the amp, it was SO NICE to have that ANC because it is truly so quiet in the cab! I was hoping to know if i COULD use the PAC AP4-CH41 (R.2) AND still keep my factory HK amp and the ANC, but simply add a filtered sub output using that AP4. I doubt ill want to change the "highs" amp as its plenty of volume for me. I do realize that the factory and the aftermarket subs may conflict a little, but honestly, the ANC is so important to my wife and to me riding with a happy wife
