Moparian
Do you have a dsp?I have my factory sub still connected with no issues.
The only cheaper option is to hack your factory harness. Just get the amp pro v2 and be done. Yes you will need to unhook the factory sub.
No I tried it without one first and never had a single issue. Others were having issues with ANC but I think it had to do with different hardware/ software revisions for the HK setup.Do you have a dsp?
Reach down behind the seats and feel for a string like loop. Pull that down and it will release the upper portion of the seat allowing it to move forward a bit. Your better off unbolting the seats from the base to access everything behind it. I found that much easier.So has anybody with a BigHorn crew cab removed the rear seats? I found 3 what look to be release tabs at the top of the seats but they don’t move at all. I am trying to see where I can mount my amp board.
Is that the standard bolt and the star head bolt on the floor? I was planning on taking the seats out anyways since I have to modify them to fit the fox acoustics box.Reach down behind the seats and feel for a string like loop. Pull that down and it will release the upper portion of the seat allowing it to move forward a bit. Your better off unbolting the seats from the base to access everything behind it. I found that much easier.
Yes if I remember correctly. I also am running the fox acoustic box. Get a few extra packs of wide washers in case you want to shim the seat up a little further. Even with the provided spacers I couldn't recline my rear seats anymore without increasing the shim height.Is that the standard bolt and the star head bolt on the floor? I was planning on taking the seats out anyways since I have to modify them to fit the fox acoustics box.
I don’t think the BigHorn seats recline unless I haven’t figured it out yet lol. Of course I never sit back there so...Yes if I remember correctly. I also am running the fox acoustic box. Get a few extra packs of wide washers in case you want to shim the seat up a little further. Even with the provided spacers I couldn't recline my rear seats anymore without increasing the shim height.
Here's a picture of what to expect when you pull your seats.So has anybody with a BigHorn crew cab removed the rear seats? I found 3 what look to be release tabs at the top of the seats but they don’t move at all. I am trying to see where I can mount my amp board.
How much room is there between the seat backs and the cab wall? I'll probably mount my board on the lower driver side, facing forward since nobody will see it, just a mono amp for my subsHere's a picture of what to expect when you pull your seats.
There are metal stand-offs that hold wire clips, etc. - I screwed into those with self-tapping metal screws to hold my amp board, worked well for me.
There is a great deal of space, 5 3/4" at the bottom, and 5 1/4" towards the top... that is with the seat bottoms folded up (the seat back moves closer to the back wall by about an inch when folded up). Plenty of room for amps - I was even able to put a pair of skinny batteries behind the seat there was so much room.How much room is there between the seat backs and the cab wall? I'll probably mount my board on the lower driver side, facing forward since nobody will see it, just a mono amp for my subs
Was thinking more liquid nails vs drilling into a brand new truck. I saw someone posted there were some plastic standoffs you could drill into as well, maybe I’ll go that route. Plan on tackling that tomorrow after I run the power cables.Yea there are so much room to work with once you take out the rear seats and carpet. I have my jl 500/1 v1 mounted right behind the driver side rear seat, also the back wall metal is very thin lol(thanks FCA), you’ll be able to drill holes through it in seconds with any kind of drill bit.
Yea I ended up drilling holes, just used silicone to seal them closed. Didn’t really see any other alternatives, I guess the poverty trim trucks don’t have the extra standoffs like I saw in some of the posts. Subs sound great though, pain in the *** somewhat but worth the hassle.I also thought about liquid nails or Velcro tapes to mount the amp, but I don’t know how well it can hold up against that old school heavy amp when off roading, so I decided to drill holes instead.
Yes, it took some work troubleshooting but very happy with it. I don't have a pic handy, but i mounted it under the passenger seat (and removed the ANC). If you have the low end stereo, the signals are not pre-amp and this is optional (the benefit is you can set timing/levels ect). If you have one of the upgraded stereo systems, you'll need this (or something like it) to process the pre-amp signals.Did you end up using this? if so did you do any pics or have any advice
What speakers are those and do they come with the adapter plate? I'm assuming thats a mid bass woofer?Was worried they might not clear since dyns are a bit deep but with a 1/4 adapter plate no rubs on front or rear.
