This is where I got the information that the HK sub is 10". https://www.harmankardon.com/ram.htmlFactory HK sub is 8 inches, not 10 inches.
You're thinking is right, you could use the factory sub as a mid bass, but you need to cut off its frequencies at the right point, and in order to do so you need a DSP.I was thinking the factory sub could still play mid bass or something. I’ve never added additional subs so this is new to me.
Perfect! That all makes sense. Thanks!You're thinking is right, you could use the factory sub as a mid bass, but you need to cut off its frequencies at the right point, and in order to do so you need a DSP.
But, in reality, your new subwoofer will be able to handle all those frequencies by itself...….
I'm not sure what cab configuration that you have, to my experience: all of the Ram's crew cabs that I owned have a tendency to over amplify the mid bass frequencies, simply by the nature of their geometrical design.
I used some liquid nails type adhesive and glued a board to the back wall. Plenty of room back there.For those with the fox acoustics vented box and crew cabs, where did you mount your amp? I don’t really want to drill into a brand new truck, I have a sheet of 3/4” mdf I could carpet and mount it to that but would it fit behind the seats? More importantly is there a way to anchor that without drilling into the cab?
Hey guys can you confirm for me the pac AmpPRO ch41 (R2) works with the 12” screen Harmon Kardon system?
im being told that the 12” screen has a different plug in the back then the other screens. So he suggested I go with the LC7i instead of the AmpPRO.
I was ready to order the AmpPRO since that’s what everyone’s recommend.
but just want to double check what everyone with 12” screens are using.
thanks for your help and input I really appreciate it.
Awesome thank you I’m going to order the pac AmpPRO today definitely sounds like the best optio.12" screen HK system here, and I confirm that the PAC AmpPro AP4-CH41 (R.2) does work with the 12" screen.
Worked fine for me.Hey guys can you confirm for me the pac AmpPRO ch41 (R2) works with the 12” screen Harmon Kardon system?
Enjoy I love mine. Running 10" jlw6v3'sJust got word my Fox Acoustics box shipped today so I should be able to get everything installed this weekend![]()
I got some 10” Rockford Fosgate R2D4’sEnjoy I love mine. Running 10" jlw6v3's
The only cheaper option is to hack your factory harness. Just get the amp pro v2 and be done. Yes you will need to unhook the factory sub.SO, I have read a lot of this thread and am a little confused. I am wanting to add an amp and sub woofer to my 2019 Laramie with Alpine system. I already have the anc bypass harness from LLJ customs.
1) Seems like I need to use the Pac AmpPro 4 AP4-CH41, are there any other options that are cheaper that will sound good?
2) I asume I need to unhook the factory sub so I don't get conflicting sound?
I have my factory sub still connected with no issues.The only cheaper option is to hack your factory harness. Just get the amp pro v2 and be done. Yes you will need to unhook the factory sub.
