2025 RAM 1500 BIGHORN 3.0 I HURRICANE twin-turbo, SO, 420HP - check engine light
well unhooked batteries did nothing accept show that the batteries are bad my volts are going between 12.5 and 14.5 when i brake they go to 14.5 when driving at 70 they 12.5 and not running 12.0 gauge is red make cel come on then goes away after i start lol i go to dealer tomorrow
I would definitely say that you have something bad in the charging system, that could be the cause for all your problems. Should be 14+ while the truck is running regardless of rpm.
so volts back to normal tech said variable alternator show me screen where it shows all the systems in the truck only thing i needed pcm update told me ill be back a lot in the next year if i keep the truck so far i have had 3 total updates 2 pcm 1 iscm truck shifts better little smother on highway at steady speed still light surge its a little less but not eliminated and tech said i did have misfire codes but no cel on dash thanks for listening
Is it possible if you can tell me if there’s a new flash for my ram. I saw there was a November 1st update someone posted that added knock sensors to the flash. I attached my last update number @Jimmy07
@Jimmy07 if possible can you tell me if there is a flash that’s currently newer then this one posted, I had one preformed on the 9th that needed with a O I believe
So currently we have 2 software updates available.These two have a whole host of updates for mulitable modules within the harness assembly.Each one of these modules are processors that act like a computer in it’s on right.This Alanitis Hi is very fast in processing speed.These software updates provide in new lanaguage so as to correct many stored faults that are occurring..Not all trigger a MIL light only certain ones that effects engine emission and driveable. One MIL light that seems to be recurring is a Auto/Stop relay # 3 stuck in closed.This will trigger a MIL Light.Also a ORB reader will clear any MIL Codes in this Atlantis Hi but I am hearing after so many starts it will reappear the code will..Also I notice people pulling the battery cable either pos or neg thinking this will reset all,but I was also told by a techthis will just show a fault for loss of power which could lead the tech in the wrong direction…So long story short these are just software updates.I see this also in many other makes and models and year.So applying lemon or dealer trade will just push the can down the road..So patience with this next gen Ram I call it a 6th gen for sure.Also this Atlantis harness is also in the 2022-2024 Jeep Grand Wagoneer is also experiencing these issue as well.
UPDATE!
Got a call back from Ram today that they will not move forward with a buy back. I asked them about updates on my truck and they just said to contact the dealer. I haven't heard from the dealer yet after leaving them a message earlier this morning. I need to find out if I'm going to have a loaner when I'm back in town tomorrow. I'm going to call Ram tomorrow as well and see what else we can do and also talk to the dealers manager.
UPDATE!
You are allowed a rental from the dealership’s fleet for the first 12,000 and then depending on the issue warranty will continue a fleet rental for you.The reason for denial for buyback is and Ram does not feel you have given the dealership enough time for the repair.One must realized not all tech’s have gone to school on this Atlantis Hi harness assembly and it is been on the Jeep GW for 2 years and not many people can afford a Grand Wagoneer L yet.So hands on is learn as you go type with tech support on the line.But dealership are sending them it is just not in large numbers maybe one at a time since there is such a shortage of tech’s right now…Also careful with a dealer trade the numbers may not come out like you would want them.But currently Rebel manufacture money has increase to 5000.00 now up from 4000.00.I myself I say stay the course.
Yeah I really don’t want to trade in and take a hit. I was hoping ram would just let me switch it for another truck. It’s been at the dealer three times and a total of 6 weeks now. Apart of lemon law, I’m wondering if I should just keep trying my luck on getting Ram to do something else?
Ram said no, have you contacted a lemon law attorney?
gw same problems as us same crap i knew it when i bought the truck it was rolling the dice and i lost and i wish it would just blow up but i will say the more you beat on better it drive then you gotta drive slow here comes the surge i will say unhooking batters fix clunky trans and i have not used sport mode since
i wanna know why level 2 rebel says front and rear light animation and it dont do it the limited does
I took a 75-mile round trip on the freeway last night to pick up my wife at the airport. By the time I got back to surface streets the hesitations have returned, pulling the battery cables only last about 100 miles-ish. Ive also now started having issues with the door mounted mirrors not returning to position after reversing (had the auto tilt down turned on) and the passenger window intermittently won't go up, it goes part way and reverses. Starting to have intermittent issues with the radio suddenly going silent while driving too. I really regret returning the first ram 1500 for the buy back, it was great with zero issues after over 1000 miles. Almost forgot, this truck also has a pretty loud knock when going over speed bumps, when the front suspension is unloading. feels like loose shock nut or shock dampening disappears near the top of the stroke.
set mirrors hit s on door then 1 but wait till your like ten mins into a drive parked i had same problem new tsb nov 16 left front strut not torqued right says to replace nhtsa website what was wrong with first ram
I've experienced similar behavior from the door mirrors. After being in the tilt-down reverse, they returned to a rather high position (I could mostly see the roof of cars around me. Maybe a default position?). I did have the mirrors saved in my profile, but it did not seem to help. I may have done what 2025 rebel junk suggested by pure coincidence since I haven't noticed an issue recently.
I've had the same issue with the passenger front window (one-click auto-up). We would be able to close it by holding the switch up through the full actuation. It took two visits to the dealer. First time they decided to order a new body panel and I had to wait weeks for it to come in. Second time they replaced the window regulator. That was last week. So far that seems to have done it.
the windows always need to closed manually after you do auto up they don't seat all the way i have noticed
