I appreciate you sending those pics. Great looking truck. Do you think 34” tires will fit in there with the 2” Mopar lift? Or is that 33 tire with 22” wheels cutting it close already?
34’s should fit with no issues. I was told that even 35’s would fit
I have 35” tires with standard suspension, no lift at all.
Could anyone tell me if a 2.5 Motofab leveling puck be too much of an angle on the cv shaft if I have the ORP ?
That's the most you want to do (3.5") over stock. All the 2.5" levels I've seen have the squatting look. Higher in the front. 2" looks better.
Thanks, I also have the 1.5 for the rear and managed to find a set of MoPar 2” UCAs, now from reading all these threads I think I should have gotten bigger tires
2020 Ram Laramie Sport. 3.5" ReadyLift SST lift, Mopar running boards, 295/60/r20 Nitto Ridge Grapplers, 20 inch Fuel Pump Wheels
Dang, how do you keep hundreds of people from seeing your license plate everyday when you drive around haha. Jk :)
Yeah, not sure why I even did that considering I posted another with the tag, and the tag is temporary.
How's the ride with the offroad package and full 3.5" SST kit?
I only installed the strut extension and Upper Control Arms from the ReadyLift kit and fit 35x12.50's on 20x9 Fuel Blitz rims. Debating if I want to install the spacers for more lift just for the looks.
I don't have the offroad package.
I did read a lot about the SST kit and Grapplers before I pulled the trigger. Many people said they didn't notice a difference in the ride. I do notice a difference. It isn't bad (a lot better than my 2018 GMC Sierra was), but definitely not nearly as smooth as stock suspension with stock tires.
Just got done installing the Readylift leveling kit with upper control arms. The extra money for the control arms is definitely worth it as the angle changes a lot. Was fairly easy to install though. Did it in under 3 hours. I still have to get the alignment done.
Unfortunately I realized my wipers aren't working and we are supposed to get rain all week long so it is at the dealership now to get it taken care of. Sucks to have to park it right after I get it looking how I like.
Here are a few quick pics. I'll take some better ones after I get it back and get it cleaned up. The pictures don't do it justice, and raising the front end up makes it look much more aggressive.
What size tires and rims do you run?
In that picture I was running 20x9s +10 offset with 275/65s. I’m running 305/55s now on 20x10 -25 offset.
Seeing all these trucks with lifts and tires, I had to break down and get mine ordered Friday. I am going with the 4" BDS Suspension Lift with Fox shocks all the way around and a set of Fuel Beast 20x10 wheels with -18mm offset and 35x11.50 Ridge Grapplers. Can't wait for the next 3 weeks to pass so I can get her done!
