1.5" strut extension and UCA's from ReadyLift 3.5" SST kit and 35x12.50x20 BFG KO2's on 20x9 +1mm Fuel Blitz rims. Factory 1" lift with North Edition.
Added 285/65R20 BFG T/A KO2’s to mine. 1.5” leveling kit with stock 20x9 wheels which are about +19mm offset. Only rub is at full lock on the OEM mud flaps. Discount Tire messed up and put a 275/65R20 on the left front, so the last 3 pictures show how the 275/65R20 would look with my setup. 3rd from last pic you can compare the front 275/65 to the rear 285/65.
2020 Laramie before:
On Saturday I swapped in a set of 275/60-20 Cooper Discoverer 4S tires on 20x9 et 0 Level 8 Hauler wheels.....here's the after:
The stock 20s with the 32" tires weigh 75lbs each. The Coopers on the Level 8 wheels weigh 80lbs each, so I gained an inch but only 5lbs of unsprung weight. Driven about 200 miles since the swap and gas mileage is unchanged. Zero difference. Tires are silent, and ride beautfiully. The Ram ride quality was a huge reason I bought the truck so as much as I wanted a bigger diameter, I was hell bent on not going to a heavy E-rated tire. And as much as I love the look of a leveled truck, I am holding off for now because I would only want the Mopar lift kit and that's not in the budget right now. Very happy with how this set up looks and performs, though. Few more angles:
Level and tires.. some of the best money I've spent on her
Looks great, those are the tires I want to get but need to know if I can fit in the parking garage at work. Do you know the height on your truck? Can you fit in a 7foot garage clearance?
Added 1/4” wheel spacers to the front and 3/8” spacers to the rear to get both axles as close as possible to same width and just make the wheels pop a tiny bit more. Still 1.5” level with the 285/65R20 BFG KO2. Also trimmed the OEM mud flaps so no more rubbing.
Looks like you need to poke a few holes in the mudflaps, looks like accumulating mud/dirt.
How are you liking that leveling kit after having it for awhile? I'm really thinking of grabbing it
Not bad, everything is normal, ride is about the same. the 22s make it ride a bit rougher with the smaller sidewall.
Yeah, they are definitely collecting crap. That's the main gripe people have with these OEM mud flaps. They do have a few slots in the bottom but clearly they don't work. I was thinking about drilling a few holes as well.
Those of you with the ReadyLift 3.5”. Have you had any issues with the lift (ie: noises, clunking etc)? How long have you had the lift on for? I’m on the verge of buying the lift but I’ve read so many conflicting posts. The ratio of trucks with the lift vs the complaints aren’t checking out. I’m willing go give up a little ride comfort for height, that seems to be the only consensus in my research.
I’ve had my readylift since Feb and I’ve had zero issues with noises.
Mopar 2” (updated) with 35x12.5x20 on a 20x9 et 1 fuel rebel.
I’ve got ORP springs in my shop, I’ll probably get around to install them this week or next at some point.
I wonder If the 22’s black appearance wheels will fit the 2” Mopar lift.
