The ride is marginally different. I wouldn't say worse, it's just slightly different. It's still smooth and a pleasure to drive. But, like all lifted trucks with larger tires, there's a little more "bounce". The aggressiveness of the tire tread pattern can be noticed. An AT/road focused tire like the Nitto Terra Grappler G2 would eliminate that. The higher elevation probably makes the biggest difference. I haven't noticed any road noise at all from the tires and the truck still rides like a Cadillac. I did notice a gear change difference from 2nd to 3rd because of the increased tire size, but again that's to be expected. Especially with my 3.21 gear ratio.
Hey, how are those tires treating you with the 3.21 gears? Do you have any issue with staying in 8th on the interstate?
(see attachment)
Saw this on Instagram, 2019 Laramie with a 2 inch leveling kit, Fuel Lethal wheels and 35 inch Toyo Open Country M/T's
Here is mine..
Leveled 2" Rough Country
20x9 0 offset Twisted Off-road
275/60/20 Nitto Ridge Grappler
Bushwacker Flares
Here is mine..
Bushwacker Flares
Ah Man are those the bushwacker 50934-02s? I've been waiting to see those on a truck. If you could take a few pics of them @ different angles it would be much appreciated!
Sure, I'll get you some tomorrow
I just got mine back from the dealership after having wheels/tires installed. I’m running a 2019 Limited; Air Suspension; Off-Road Group/Package (adds extra 1” lift); long bed, and had Fuel Vapors (20x9 +20 offset) with Nitto Ridge Grapplers 35x11.50. Zero rubbing at full lock, zero cutting. After searching this site, reviewing multiple threads, I’m confident that this is the largest tire (20”wheel) you’ll fit on a limited with air suspension. Had I not added the off-road package, they would have rubbed. Less than 1/2” clearance at full lock.
Would love to know what the forum thinks.
Tires look great. Good work
Limited with air suspension. Added the largest non LT Ridge Grapplers (305/55/20) to maximize the ride comfort on Fuel Rebel 20x9 +1 offset wheels (d680). I also had Daystar spacer installed up front to keep my ride close to stock, along with previously installed revel links to level the front - still need to optimize this. No rubbing or cutting. Posting pics to the chain. Let me know if anyone local and interested in stock ORG Falkens on rims/TPMS.
IMG_20190513_194357.jpgIMG_20190513_194335.jpgIMG_20190513_194301.jpgIMG_20190513_194324.jpgIMG_20190513_194236.jpgIMG_20190511_162337.jpgMVIMG_20190511_162412.jpgMVIMG_20190511_162306.jpg
Sorry for the delay. Here you go!
Thanks so much for following through! I love the clean look these fender flares give the truck. Were they difficult to install? and did they give you and additional clearance issues with your tires?
[/QUOTE
They were extremely easy to install factory
extremely easy to install using factory bolts and threaded retainers. No clearance issues at all. Thanks for the comments.
Motofab 2.5” spacer level with Hardcore H500 22x12-44 offset nitto 420’s 305/45/22. Completed last night. Currently at alignment shop. Will post better pics later. Need to research how to get the tires to rotate evenly.
^^^. Why nice, I’ve always been a fan of Vossen wheels. Had a couple sets on my last show car, never thought about trying a set for this truck.
I was thinking about spraying in the bed liner hot rod red. Your thoughts?
