2019 RAM Rebel Lift Kit
The Rebels do have different front struts. They have Bilsteins so the spring perch could very well be different from the ORP trucks.
Today I climbed under a Rebel - in the wet no less - and got a rough measurement. The Rebel's spring perch is the same location as a non-ORP and ORP spring perch (8.25" from bottom bolt-center to lowest point on spring perch [the coil stop]) [I have ORP and non-ORP shock units in my garage right now]. I also confirmed that the Rebel has the same spring part number as the ORP (68320249AB), which is 3/4" taller than non-ORP (which translates into a 1" lift). It's the spring, not the shock, that lifts the rebel (and ORP), and that spring should also add 1" to the mopar lift)...Add that to the fact that I started my debate a while ago with the fact that the dealership where I got my ORP shocks (F&R) from had done a Mopar lift on the truck that originally had that ORP stuff and they swear it lifted the truck 3".
I stand firm in the fact that the mopar kit will lift the Rebel and ORP trucks to 3", BUT it won't actually work on the rebel because the bilstein is a different tube diameter (I didn't have a micrometer and did my best with the tape measure, but it was apparent) and a different spring perch diameter, and the Mopar kit requires you to reuse the spring perch from your stock shocks - and the bilstein perch doesn't fit the fox shock. That's why they say it won't fit the Rebel, but they don't say it won't fit the off-road package trucks (because the ORP and non-ORP spring perchs are identical). I confirmed with Mopar a while ago that they only claim "Not for Rebel", they do NOT claim not for ORP.
If you put a non-ORP spring onto a Fox shock, you'll get 2" of lift - we know that.
If you put an ORP spring, which is 3/4' taller and creates 1" of lift, onto a fox shock, you'll get 3" of lift. If I had an extra $1200 and lots of time, I'd prove it ;)!
Just my two cents. The Dodge Dealer where I bought my truck said if I use the readylift 3.5", I will be 4.5" higher than regular Rams. He also said if I had them install it, any issues with the drive shaft and/or any other parts damaged by being out of whack will be covered by my bumper to bumper 100k warranty.
At this point, it sounds like waiting for a Stage 2 kit from someone like Pro Comp is warranted.
MOTOFAB 2" level with the Mopar 2"lift upper control arms. Running winter tires and rims on it now but have the stock wheels with 295/70-18 Nitto's I run in summer. No issues, ride same as stock. Measures 39 3/4" front and 40 1/2" in rearIMG_1442.jpg
I installed the ReadyLIFT 2" Leveling kit with the UCA's. Really only lifts 1.5", but does look much better. I may put the rest of the 3.5" lift on this next summer.View attachment 4452
hello ,I won’t same this lift kit Where can I get it ? and how many this left kit ?
Hey, thanks again. I think I'll install the front leveling kit, then decide if I want the rake or not. Either way it will look better.
Any updated pictures with just the 2” lift all the way around . Just ordered my Rebel and trying to figure out what to do. Thanks.
First is before second one is after 3.5" Readylift only using 2" in the front and not the whole 3.5"
Had the Daystar spacer kit for a 4th gen Ram installed, rides very close to stock. 20s and 35s going on tomorrow.
Did you get your 35’s on? No rubbing. How wide wheels? Pics?
I’ve been following this thread for a while. Has anyone figured out if I get a 6” (full kit type of deal), would it work since I’m essentially replacing or relocating all of the components?
There's a few of us here who have 6" lifts installed on our Rebels. I encountered a few differences between the instruction sheet Fabtech sent and my actual truck but nothing major. Lift went on just fine with no problems and I've had it on for about 4k miles now. The alignment was done right after the lift and everything is good. I went with the Fabtech 6" Basic lift. I have pics of the install posted on my Insta @rebelram19 if you care to see the differences I encountered.
Any ride degradation? I'm considering this lift but don't want to compromise the ride. I also want sound geometry so I'm getting an education in this thread.
You also have the wheels I'm looking at. Are the Fuel wheels you have 18's ?
And who's truck is this? The lift/wheel combo looks to be exactly what I'm looking for:
7af8e8ac-3780-4b89-8a46-753b6bc827cb-jpeg.21196
True, but the speed is also limited. I think offroad 2 it automatically lowers back down after you hit 15 or 20 mph. With a leveling kit, it is raised 24/7 no matter what speed, and a bad angle can lead to more damage.
Where did you get that information that it auto lowers at 15-20? I haven't seen that published nor on any of the REBEL YouTube vids. Not saying it is not true, just would like to see the definitive source of your statement.
It’s been talked about here in multiple threads. I would have to do some searching to pinpoint it. When raised into off-road 2 the cv angles, ball joint angles, etc are pushed to the max. If hitting something at full speed with those angles you could potentially cause some damage.
It's in the manual - Off Road (max) height will auto-lower after 27mph, and entry/exit will auto raise after 17mph
I'd like to see them put that in writing.
Are all of these options for the coil rebels only? I'm wondering if there are any options for us air suspension rebel folks. Not much coming up in the searches.
Any idea on this? I emailed ADD and they said the customer already had the lift when they installed the bumper, and now this picture is no longer in the site. But form what I can see, everything looks good....
