wildh24
- Dec 23, 2018
I actually did verify every speaker with a battery during installation. I pulled the speaker, noted the orientation of the stock harness, tested the speaker with a battery, marked the positive, and then adjusted the Metra harnesses to match. Then double checked.
. I'm fairly certain all 6x9s are working in + polarity. (Unless the factory did not actually send a + signal on that specific wire... In which case I would need to verify with a speaker pop app or osscilscope). I found the app to be highly inconsistent in my use.
I would consider an active crossover but there again it's a lot of wire slicing since it'd have to be done after the factory amp.
I'm probably overthinking everything. It's great on 99.8% of music and that one note was the only thing that was wonky. It was on Lorde's 'Green Light' and her stuff is very bass heavy.
