Wxgs333
- Sep 3, 2018
also not
sure I would like looking at the cut/split line in my tailgate.
This is exactly what I was thinking....
also not
Right so if the current tailgate is 30 add 75 I just don't know the weight of the current.
I note jordan2929 is having difficulties getting the wiring diagram to post, but would it be permissible for it to be shared directly via regular email to the members? I'd like to be able to have a look at it, and do some circuit tracing.
Will do during lunch todayI just increased the maximum attachment file size so it could be tried again. If it still doesn't work @Jordan2929 shoot me an email and I'll get it up here for everyone.
The article answers a bunch of questions. Much appreciated.
My opinion - should have located the 60 swing handle under the taiilgate near the splice (similar to ridgeline). Reasoning:
Sounds like they've been testing for a while, so it should perform well.
- Could have allowed for a mechanical latch instead of electrical - so retrofit and potential on non-rambox trucks would have been possible
- You would then guide the bottom corner of the 60 out with your hand, saving it from hitting jack handles potentially
One question - I assume the bed extender side lugs cannot be used when tailgate is dropped standard?
I keep hearing this is only available with the BUG, but do you have to get the ram box as well?
Excellent info in the article.@redriderbob posted the article a few posts up. It states the new tailgate is only available with RamBox due to the electrical wiring required.
Thank you for posting
Could I add this to my current ram box equipped truck?
