Hard-wire Dash Cam Install
Would love to put a bed cam and front grill cam in my new 2023 Ram but just don't want to take my grill out to do ii...lol. No pain no gain I guess. Thought Sure when I ordered my Truck I had ordered the 360 cams but I did not by mistake. ):
Installed the Blackvue today thanks to this thread! I do have one remaining question though…In the Blackvue manual it calls out the hazard light fuse location to be used for the battery saver feature. Is there a specific reason for this exact fuse? I used locations F-33 & F-66 like this thread called out, but I want to be sure.
Big shout out to securityguy for helping me with my dash cam install. I thought it would be simple to install a Viofo A119 mini 2, but of course, I ran into issues. Turned out I had a bad camera. Replaced it with a new one and now everything is working perfectly. I really appreciate this forum and its members for the ideas and help!
Those of you who have installed in the RAM, Blendmount or right on the glass? Thoughts? Looking at the Blackview 970x
I have my radar detector on my Blendmount and always install the dash cams directly to the glass. Blackvue is my #1 go to for dash cams. www.thedashcamstore.com
I wasn't interested in having my dashcam run 24/7. Only wanted it while driving. Have the Escort M1 dashcam, mounted on a BlendMount support. Used a MirrorTap for power, so the dashcam only operates when the power mirror does (ignition on, ACC on, etc.). Clean and efficient, with no wires hanging in my face. The Escort M1 is designed to work in conjunction with a radar detector, and I do not have a radar detector presently (usually drive conservatively) but may purchase one some time in the future. The additional wire coming out of the side of the dashcam (shown hanging loose in the second picture) is the factory supplied power source for the future detector. The power goes through the camera and into the detector. I just have the short detector power cord tied/tucked up out of the way for the time being.
How did you tap into the mirror power?
I am using this topic again. I bought a new dashcam. Again from Viofo.
I had a few times with my previous one that the dashcam often restarts during driving. So I updated the firmware and such but it was still the case. it seemed better with unplugging my rear dashcam. But I was also wondering if it could be the fuse taps or connection?
Thanks to the topic I use F33 and F66 and used fuse taps so that I can place 2 in the spot of 1. I will now connect the cables better (as far as possible) and make sure to check the connection thoroughly.
But I was wondering if there are any other spare slots that can be used for battery and accessory fuses? So they have a slot on their own.
Thanks to this thread, I just completed install of my Fathers Day gift from my girls. A Rayfoto LS05D and hardwire kit.
Didnt want it on my windshield, instead mounted it to my clip on wide angle rear view mirror.
Ran the wires for the hard wire kit and rear view cam up through the mirror mount and head liner.
Again, this thread was very helpful in the install.
Routing the cables was super easy, plus having enough fuse taps made the install a breeze.
For the rear camera, I used a strip of ABS plastic, mounted the cam to that, then mounted that to the window frame with 3M tape, so it now sits below the frame.
Have watched videos of this Rayfoto cam, seems a decent dash cam. Havent taken it on the road yet, just ensured at this point of a clean, working install, and I can connect to it through the app on my Android and iPad.
Been wanting to get one for a while, so to get it for a gift, cool man! That makes it an awesome cam! 🤙
Ok, i may have thrown a hint or two...lol.
What bracket did you use to mount your rear camera? Thanks!
Does anyone have the correct fuse locations for hardwire with parking mode on a 2026? I’m installing a Thinkware U3000 Pro and decided to hardwire instead of using the supplied OBD power cable.
Dongar connector, plug and play with the rear camera connectors. Optional, I just drill a small hole on the plastic cover, use a rubber grommet (pack of grommets at Harbor Freight) to cover the hole on the passenger side where I placed my camera. You don't need to do this, you can just pinch the wire against the plastic, still looks clean.
Results in a very clean installation, here is a good video of someone doing it, however I recommend placing your camera to the right of the rear view mirror to keep it out of your line of sight when driving. Also remember that dash cams have screen savers, usually off by default, I would set it at 30 seconds, that way you don't have a little "tv" on all the time distracting you while driving.
I looked at that video before that's the way to go ! It's a very clean way to go.
