TPMS reset after changing wheels and tires?
I have no experience with a tool like that. I'm curious if it would sense the Ram 1500 Rebel TPMS sensors?
I really hate sounding stupid. I just learned the Rebel tire pressure is 55 in front and 45 in back. I had them inflated to 40 psi. Could it be my Bighorn is not reading the TPMS sensors because the pressure is too low?
No thats not it. The sensors will read down to low pressure. Maybe the wheels and tires came from canada or something? I bought some ram wheels from a limited that looked a little different than anything I've seen and despite having oem sensors they were all dead and didn't register. No tool would wake them up. Had to put new ones in. So the only real solution is you need a TPMS tool, or take it to a tire shop. The tire shops will have the right tool. Most will scan for free because the sensors are most likely broken or wrong and they will sell and install their house brand.
I hate to keep this going. My local mechanic determined sensors are there but said he would have to change them out to work. I guess that means he can't change the settings in the computer? My guess is my friendly Ram dealer can.
You can change the IDs in the ecu with a tool like the autel with an OBD security bypass cable. I almost went this route but decided modifying the ecu is more risk/expensive than just getting the correct sensors that the ecu is factory programmed to use. The dealer would mist likely just tell you that new sensors are needed as well at a much larger expense. Ive been where you are plenty of times and it a bummer to shell out cash for new sensors but then at least you know the valvestems are brand new and you get a rotation and balance out of the deal.
The OEM sensors are in the Rebel wheels. I'm guessing Ram can fix that.
Let us know when you get them going and the steps to get you there.
I have a 2022 RAM 2500 6.4 Tradesman. I upgraded the rins and tires off another ram to the black 20” and the tpms took a week to register. Then last week i put a new battery in and now rhe tpms is unavailable and all tires read 0. Ive driven a few hundred miles and no change. I went to a tire shop and they used the tool and said none were respnding and all were dead. I find that hard to believe. Any one have any experience with similar issues?
If they took a week to register initially, the batteries were probably very weak. They should register in a few minutes / few miles. The batteries are likely too low now for the reset ecu to pickup.
Thanks the sensors and tires are only two years old. The wheels actually sat in a garage for a year before i put them on. Would that seem strange for all 4 to be dead?
I finally got to the dealer for service and spoke to a knowledgeable technician about my TPMS issue. According to the technician, there was a frequency change between 2022 (315 MHz) qnd 2023 (433 MHz). Makes sense but I am trying to verify this.
When I change wheels on my 2021 and bought new TPMS sensors, I am pretty sure they were 433MHz. I had no issue after driving about 5 to 10 miles they started reading and no issues since.
Mine in my 2019 ram bighorn are 433Mhz as well. Im pretty sure all rams, all trims use the 433Mhz. You need to verify if they are still alive with a tpms tool, and if they are indeed alive, that they are the correct frequency and compatible IDs. You never know.. ram wheels fit chevy trucks, maybe someone was running them on a chevy and put chevy tpms valve-stems in there! Ive been down this road and they only way to properly troubleshoot is using a dedicated TPMS tool to verify what you have going on. Wish you were local I would run a scan on it with my tool. Any tire shop can handle this as well.
Hi All new to the site.
Purchased a set of Fuel Rims from a Fuel dealer back in April for my 2023 Rebel Havoc. I went form the Stock 18" rims to 20" Fuel rims. The TPMS was working fine till about June then it stopped working. The Fuel dealer tried to reset it and had no luck. Took it to my Ram dealer and then told me that it might be the off set. I told them nope it is a zero offset. They said the had a 2500 Ram in the shop for the last 3 days that was having the same problem. They told me that they spoke to the factory engineers at Stellantis and they didn't have an answer. Sooo any help or advice would be appreciated. I am gonna go home and pull they negative cable tonight for 10 mins and see if that works. Again any help would be appreciated
So I took some advice from this site . Went home disconnected the neg. battery cable for 10 mins to reset everything hoping the TPMS would reset but it didn't work. Gionna call Fuel Wheels today and see if they have any bright ideas.:rolleyes:
I can't imagine how the Fuel wheel or offset could be the problem. Tons of trucks on this site are running plus/zero/negative offsets without a problem.
I do know on my new Fuel Variant 20x9 +1mm offset wheels, I used TPMSdirect metal stemmed 433mhz sensors..they auto-programmed after about 5miles & 5minutes, but all 4 read 1psi higher than I set them digital air guage that reads to .0 measurements. My OEM rubber stemmed TPMS were spot on to my guage. I figure either my new ones aren't as accurate😡 or the offset makes them less accurate(?)🤔
...and by "some", you mean "most"😪
Yup Absolutely. Especially after I drop my truck for the TPMS problem and the service advisor calls me 30 mins later and tells me that they don't and cant fix the problem. I tell them well I am coming back and pick up my truck because if you cant fix your not keeping it over night. UNFREAKING BELIVABLE . (SHAKING MY HEAD)
I’m currently sitting with my hood up and battery disconnected at a local tire shop that I ordered some new Toyo Ridge grappler.
Paid extra to have them install new sensors since I had one that was bad.
Went for a test drive!
Noticed an obvious shimmy that gets worse the faster you go. Sensors did not work got the temporary unavailable message.
Came back to the shop, was told the vibration is probably the spacers I have installed that aren’t hubcentric.
Immediately said no, sir! They are hubcentric and have not had an issue in five years that they’ve been on the truck. Smooth as glass up until now.
Don’t like being lied to!
Then he tells me that you have to wait 20 minutes before you go for your first drive to reset. Why didn’t they say that to begin with?
Once I reconnect the battery, I’m going to let it sit for the 20 minutes they recommend. Then go for a test drive for 20 to 30 minutes above 30 miles an hour if that doesn’t work I’m gonna request a refund on the sensors and order the Mopar ones!
Which is what I should’ve done in the first place.
