Not sure, i got mine from Jimmy07 on this forum. Quality harness for both doors and rear antenna. He even labels the wires for the terminal they go into and driver/passenger.Does any one know if this harness that’s sold by Mopar, is the harness that plugs into the door handles and the wire loom to the door body for adding the passive door lock?
It doesn’t have the ends to plug into the door, and might not be long enough on page one you can see the part numbers and add the ends, or make you own wires or pay jimmy.Does any one know if this harness that’s sold by Mopar, is the harness that plugs into the door handles and the wire loom to the door body for adding the passive door lock?
You do if you want the tailgate to be passive. You might get better communication with it, but it isn't required.I'm going to make my own harness. Do I need the rear antenna? I only want the 2 front doors to be passive
I don't need it to be passive. My 14 has passive locks without the tailgate and I was fine with it. After looking through the post someone mentioned an error code because the didn't install the rear antenna. They had to change am ap5 trunk setting in alpha obd?You do if you want the tailgate to be passive. You might get better communication with it, but it isn't required.
This is the easiest part. Looking up from under the spare tire, on the left side is a plug with a dummy cap plugged into it. Plug your antenna in to this plug. That’s it!
Yes according to him if you have a heavy duty 2500 it is there is 1500 its notOk. Ima little confused on the rear antenna install. It's shows a parts for installing the antenna but this is saying you just find the plug and plug it in?
Did you ever find them ? That’s all I lackI was looking for the same, Has anyone done this on a 2021?
No ,doesn't look like they are in all the way, you should not see any metal. Make sure they are in the correct direction, I believe they only go in one direction, try rotating 180degrees. You should here and feel a click, should not take a lot of force and they will not pull back out.I did msg Jimmy to ask but thought I'd ask here as well. Doing passenger side first...do these look properly seated? There wasn't really a big "snap" into place.
Also look on the other side of the terminal block, they should be sticking out the same as the other pins.I did msg Jimmy to ask but thought I'd ask here as well. Doing passenger side first...do these look properly seated? There wasn't really a big "snap" into place.
this is the part in the door, not under the car. Tee ones under the truck for the rear fascia DID snap in.Also look on the other side of the terminal block, they should be sticking out the same as the other pins.
How much would they costIf anybody doesn’t want to spend the money for the entire door harnesses and rear facia harness, and doesn’t feel like building the add on harnesses with the parts, let me know and I can build them for you-![]()
Don't think I can see the pins on the other side, at least without removing the other plugs.
AND now I need to order new male pins, damaged one of them try to get it through the boot.
ETA: I decided to try and finish up and see how it went since I was like 90% done. I "re-jimmied"the male pin, finished the install and did the JSCAN changes. Well, what do ya know....everything works! Woohoo!
The male pins for the doors did seem to "set" in but didn't fully snap in like the ones for the rear fascia.
I ordered some replacement pins, if it stops working I'm reasonably confident where the problem might lie since I re-crimped the one.
Longs like you didn’t relase the locking clips one the opposite side?I did msg Jimmy to ask but thought I'd ask here as well. Doing passenger side first...do these look properly seated? There wasn't really a big "snap" into place.
huh, okay I definitely missed that step, thought it was specific to the HD. also didnt see this in the video from Info but maybe they used different clips.Longs like you didn’t relase the locking clips one the opposite side? View attachment 200373
