Adding Passive Entry: How-to
If you’re from New England and you’re needing assistance or anything like that, feel free to reach out I also have a Facebook page that I just started geared towards people from New England but anyone can join
Configuring the BCM for passive entry with AlfaOBD.
Grab your SGW bypass and locate the Security Gateway. If you are unfamiliar with its location, it is located up inside the driver’s side footwell, behind where the headlight/parking brake switches are. The below pic shows the module, looking directly up from the floor. It's the black box with 2 connections on it, located right by the green and white star connectors.
*From what I have read, the bypass on the HD's is located behind the instrument panel and is a little more involved to access. Once I can confirm this and possibly get a photo of its location I will update this.
Release the connectors from the gateway and plug them into your bypass. That’s all there is to it.
Next, plug your OBD interface into the OBD port, which is located on the bottom edge of panel under the steering column. You should have no issues locating it, as it’s the only exposed connector in that area and will match up with your interface. If you haven’t done so already, set up your OBD interface with your tablet or computer via a Bluetooth or wireless connection.
With your foot off the brake pedal, press the Start/Stop button on the truck 2 times to place the ignition in to “Run”. Do not start the truck, just cycle the ignition to the “Run” position.
Once that is done, we are ready to make the changes in AlfaOBD. I opted not to include photos here since if you follow the steps one at a time you should have no issues. I do have screenshots, so if you need a visual to go along, I can get them added in.
Open up the app on your device and you should see the home screen.
To begin, click on the Bluetooth or Wi-Fi icon and connect to your OBD interface.
Once connected, select the Dodge/Ram icon.
On the first drop down menu choose your vehicle model.
On the 2nd drop down select “Body Computer”.
On the 3rd drop down you will need to select the appropriate BCM for your vehicle. For my 2020 I chose the very last one in the list.
The app should advance to a new screen where you can connect to the body computer. Once connected, it’s time to get in to making the changes needed.
Select the little icon in the bottom right that looks like a car with the hood open.
Select the drop down menu and go all the way to the bottom and select “Car configuration change”.
You should now have 2 additional drop downs below the top one. The top one will still say Car configuration change, and we aren’t going to mess with that one anymore. The next one down, the middle one, is where you are going to begin selecting the items to change.
Take your time and be sure you select the correct one each time as you proceed. To keep things simple, just start at the top and go down the list below, enabling and/or verifying each item as you go.
After selecting a setting to change in the middle drop-down, you will then select the command using the bottom menu. Reference the list below and make your selection based off the setting in bold.
After selecting the command in the bottom menu, hit “start”. The app will first verify the vehicle setting and give you a message indicating its current set state. If its current state is not set to what it shows in bold in the list below, press “start” again and this will make the change. You should get some text at the bottom saying the procedure was completed, however it did not always come up for me. If it doesn’t say it was completed, just hit start again and it will check the current status and tell you what it is. If it’s correct, move on to the next one.
The following list is all the settings you need to change or verify to enable Passive Entry. Each setting name is given, followed by the state it needs to be set to in bold. I made all the changes sequentially without cycling the ignition at all in between and everything worked just fine. Take your time as the full list in the app is long and you can easily scroll past a setting, especially the wireless ones as there are only a few. (The newer version of AlfaOBD allows you to search for a specific setting, so you can begin typing in the search bar and it will start narrowing down the list if you don't want to scroll through everything. Just make sure you keep track of the ones you change as you move down the list)
PASSIVE ENTRY BCM SETTINGS
VehConfig 3 fobik safe enable- YES
VehConfig 3 passive entry present- YES
LIN and Misc fobik safe alert no reply- YES
LIN and Misc fobik safe alert on system fault- YES
LIN and Misc fobik safe alert on search timeout- YES
LIN and Misc fobik safe alert per ignition cycle counter- 2
Wireless AP1 Left front- SMART SWITCH
Wireless AP2 Right front- SMART SWITCH
CustSetMenu 1 passive entry CSM present- YES
Cust.Prog.Features- Passive Entry Unlock All Doors or Approach Door- ENABLED
IMPORTANT NOTE:
With the configuration set as above, if you do not have all the hardware installed (such as the 5th antenna) fobiksafe will not operate as designed and there will be fault codes stored in the rfhub. If you utilize the inside lock button to lock the doors as you exit, whether or not the fob is inside, you will get an alert from fobiksafe and the locks will auto-unlock after closing. There is the small chance you could lock your fob in the truck if you ignore the warning since it doesn't actually know whether the fob is inside or not, and on the 3rd attempt the doors will remain locked. Once everything required for PE is installed, the whole system will function as intended from the factory…alerting you only if it senses a fob left inside the truck so you do not lock yourself out.
Once all the settings have been made you can cycle the ignition back to off. You can also remove the SGW bypass and OBD interface now.
Go ahead and disconnect the battery and let it sit for a bit. Anywhere from 15-30 min should be sufficient. The intent is to ensure the RF Hub re-reads and picks up on the new BCM configuration the next ignition cycle. (Although this may not be totally necessary, it isn't going to hurt anything)
This was initially completed on my '20 Bighorn which had the 8.4 non-nav unit. If you have nav, it may take a bit longer to show up in Uconnect, so don’t freak out if it isn't there right away. Give it a few ignition cycles and everything should show up. The actual passive entry will likely function even before the setting shows up in the menu. You will be able to find the passive entry option in settings, under “doors and locks" on your screen.
If you plan on adding the antenna and wiring to the rear of the truck, refer to the post that pertains to your specific model year.
This was really helpful. Thanks so much.
2019 & 2020 Rear Antenna Install
This will help guide you through the basic process of adding the rear antenna to a 2019-2020 5TH-Gen 1500. Whether you use your own wiring, or replace the entire rear fascia harness, the antenna location will be the same. If using the factory harness, it’s going to be plug and play so just remove and replace the entire thing. If you’re just adding the 2 wires needed, then follow the steps below.
To add the two wires and connector for the rear antenna, start by finding the connector below, which is where the rear fascia connector plugs in to the body harness. It's right above the rear resonator on the driver's side.
To unplug it, pull up on the little yellow tab and then the red piece will slide out. If the connector doesn’t pop off, you haven't pulled the red piece out enough. It will disengage on its own once you slide it out far enough.
Once unplugged, remove the first couple of clips from the frame so you have some slack, then remove the black cover from the backside of the rear fascia connector. You should be looking at something like this, and we will be working with terminal positions 19 and 20. Position 19 is the "PASSIVE ENTRY ANTENNA 5 SIGNAL" and position 20 is the "PASSIVE ENTRY ANTENNA 5 RETURN". Refer to the photo at the end of this post which shows the antenna connector and which wire is which.
There will probably be little plugs in the terminal positions, so you need to push them out. If you have a tool for depinning connectors, slide it in the terminal positions from the face side of the connector (photo directly below) and the plugs will push right out. If you do not have one, a small piece of wire or a paperclip will likely work just as well.
Once the plugs are out, before you can insert the terminals from your new harness, there is a plate that needs to be slid out of the way. In the photo below you can see it slid out of the connector, to the opposite side of the one you moved to unplug it. A small flathead should be all you need to get it started and then just slide it out far enough to access the positions you need.
After that you can insert the new terminals into the backside of the connector. Don't force them in, they should go in with very little effort if they are oriented correctly. You will hear them click into place when they are seated. Once they're both in, slide the red tray back in.
You can then install the black cover on the back of the connector, and route your wiring however you choose over to the antenna. I ran the new harness inside the first section of wire loom so that it was contained in the black cover like all the rest, then I taped it all up and just ran the wires alongside the factory harness.
The photo below shows where the antenna mounts in a little cubby behind the center of the rear bumper. If you look up from under the truck, between the spare tire and bumper you will see it. If you drop the spare down you will have room to work and come up with a way of securing it with clips or small bolts.
I need to remove the terminals to check continuity. Which de pinning tool do I need? A picture would really help!!
Just got a used 2025 Rebel after trading in my 2019 Rebel. Of course I didn't even pay attention to the 2025 not having passive entry and just assumed it would have it like my 2019.
Is there an option yet to switch out these **** *** door handles for the passive ones yet? Most of what I have seen says is up to 2024 and that 2025 is different now.
I'd really like the truck more if I could get that back and now miss my 2019 🤣
Asked and answered many times. No, not at this time. See above.
Same with my big horn. I did a bunch of research, and how I didn't realize it didn't have it is funny. I think I read Remote Keyless–Entry
and just figured it had passive entry, and lets not even get into the digital key that Ram just lists on their website for 2025 1500's, and not indicate only on the highest trims.
Thanks I just got a kit like that yesterday. But which individual one do I use. I don’t want to try figuring it out whole under my truck
I’m not sure. You would just need to see which one fits i would think any of the smaller ones to release the tab
Does anyone know how to de pin the wires from this connector?
"If you have a tool for depinning connectors, slide it in the terminal positions from the face side of the connector (photo directly below) and the plugs will push right out. If you do not have one, a small piece of wire or a paperclip will likely work just as well."
I am hoping someone might be able to help me.
I am trying to make both rear doors passive entry via the passenger side and keep the front driver door separate. The idea is to keep the front driver door the only one to unlock via driver front door passive entry.
I asked Jimmy07 about this and he said "Yes, that’s what you’ll have to do if you want to keep that setting."
I got the rear passenger door to work. What I am trying to do is have the rear driver door operate the same way by connecting to the rear passenger door wiring.
I have tried by splicing into the 1 and 7 wires for the rear door where it runs inside the door column to the 1 and 7 wires that should tap into green/white and green/yellow wires on the drivers side. That did not work. There is no response from the driver rear door handle but the passenger rear door handle still works.
I swapped out handles on the rear driver and passenger doors and it still worked on the passenger side so it's not the handles.
I disconnected from the splices on the passenger side and connected the driver side to the splices but that didn't work.
I tested for continuity between the rear driver door handle plug and the other ends of the harness wires from Jimmy07 and that checked out.
Right now I am at a loss on how this is not working. Logically it makes sense that it should.
I did the exact same thing, both rear doors wired to passenger front door wires. Here's the problem the key fob MUST be on the same side of the truck as the handle your activating. Because the drivers rear door is wired to passenger side, it sees the fob and sees the switch activation, but ignores it because the programming is set up to ignore opposite side activation. Set up like this, if you watch the LED in the fob while activating driver rear door switches, you'll see LED flash but no lock/unlock. If you put key fob next to passenger side, drivers side rear door will operate as it should, but drivers door will not.
Can anyone tell me if the factory Big Horn tailgate handle is passive entry capable?
The handle doesn't matter. You don't need a special handle. You need the rear antenna installed.
If anybody doesn’t want to spend the money for the entire door harnesses and rear facia harness, and doesn’t feel like building the add on harnesses with the parts, let me know and I can build them for you-
Still building these?
I ordered and paid (zelle) on 10/15 and quoted 3 day lead time. Expected they would ship in a week or so. Received the cables and they’re great quality. Install was easy and I’d highly recommend @Jimmy07 and his work.
Happy Veterans Days!
I wanted to pass along that the install to gain passive entry went flawlessly this past weekend. Thank you @MayhemMOORE for the original write-up, @Jimmy07 for the quality harnesses and everyone else who contributed both insights and issues!
Just a side note, since I have a BTS, the handles were the matt textured black and I really wanted to keep that look. I contemplated different options, from retrofitting the PE guts into the existing handles (no-go, way too much work), using the Diamond Black as is (way too glossy and didn't look right) to finally ending up with a complete refinish of the Diamond Black handles and tailgate (also installed the 360 surround). In the end, I am pleased with the results.
For reference, I used the following parts and supplies:
Harnesses from Jimmy
Door handles (Diamond Black) - 6cv64kxjad
Left Cap - 6cv50kxjac
Right Cap - 6cv52kxjab
Rear Antenna - 52112204aa
Sound Deadening Mat (I figured since it was all exposed, I would try to get rid of that hollow tinny sound from the external door panels. All I can say is night and day difference! When I knock on the outside of the door sheet metal, the sound is a flat thud now!) - https://a.co/d/9hDt5jI
For the handle refinish, I used my Dremel with an abrasive wheel to remove the factory gloss finish, then prepped and painted using the SEM plastic refinishing system:
Abrasive wheels - https://a.co/d/6bXV4oX
SEM Prep Soap - Amazon.com: SEM 39362 Prep Soap for Automotive Refinishing Vinyl, Plastic and Leather Materials, 15 oz : Automotive
SEM Plastic Prep - Amazon.com: SEM 38353 Plastic Prep - 12 oz. : Automotive
SEM Adhesion Promoter - Amazon.com: SEM 39863 Plastic Adhesion Promoter Aerosol - 14.8 oz. : Automotive
SEM Texture Coating (After it flashed, I knocked it down and sanded with 1000 grit to keep the texture look but the handles feel smooth) - https://a.co/d/6bdldqr
SEM Ultra Black Matt Trim basecoat (3x coats) - https://a.co/d/0FO6PGX
SEM High Solids Matt Clear (3x coats) - https://a.co/d/7Zdu7yC
Overall, happy with the results. It was more work ahead of time, with taking a week to refinish the handles, but glad it is done, working and oh so convenient!
I am going to do this on my Bright White 2500 and my buddy wants to do it on his '22 1500 Rebel. His door handles are black plastic. Do they make the plastic handles with the passive entry for the Rebel? I can't find any part numbers for them.
