HOW TO: Add 360 Surround View Camera System
Asking one more question abiut the braket. I found online a smashed mirror that does not have the full assembly but the lower section of plastic that has the camera looks in tact. Does anyone thing I could just take that section and put it on my current tow mirror? I am not sure if that can snap in or I would need to cut but either seems reasonable.
It's possible. But you could also take the camera and bracket and put it in your mirror. You'd just need to drill the hole for the camera. It's not hard.
if anyone knows a guy in central Texas that will do this I'd rather pay to have it done :D I have way too many projects as it is right meow
hi all, I was going back and forth between just installing a 3rd party front camera and doing this whole project. And then.....
My wife smashed the passenger mirror to bits. :). So, since I need to buy a whole mirror anyways, I figure I might as well do it this way. I know I can retro the 360 camera as discussed above by harvesting the bracket and howefully having it with a working camera. I was going to look on ebay to find one, but when I went on Mopar to figure out what the right mirror assembly is in the first Place, I got utterly overloaded.
I ahve a 2024 power wagon with tow mirrors, blind spot monitor, but no 360. Does anyone know what the part is?
I also wanted to check in and see if I really need to buy a new backup camera as I cant imagine its a different wide angle lens.
If anyone has done the 21-24 2500 reciently that has an updated parts list that would be amazing.
Thanks
You'd have much better luck with this on hdrams.com
There's also a guy running a thread that will look up part numbers if you supply a VIN. If you're truck didn't have what you need, and you can find one in inventory or someone that has that option and use their VIN, you'll have better odds getting it right.
