I went through 2 weeks of buying part, combine information and gets the cameras working.
I bought a 250 USD mopar trailer camera kits. There quite a lot of these things floating around and people get rid of them . They came with 4 cameras ,4 extended long fakra coax cables (5-8meters ) with different color code for Front Back Left Right at CVPM input , a MOPAR plastic Black Box which if open inside, there is a 4 port CVPM , with conversion Fakra cables for different color Fakra connectors, 2 long harnesses which i am still trying to understand it, 1 harness has the input plug for the CVPM , which fit all of the CVPM i bought.
@hydroblue2022TRX : you need to buy a Surround View CVPM . There are 4,5,6 port of input different CVPM models , depends on how many cameras you want to add. I think it will works with all model at least to my 2021 Ram 1500 Laramie. I have tried 3 different CVPMs. Manage to read from Front , Back, Left, Right, and Third Brake light location
you can utilize just the front and back port for your front and backview camera. installation and routing the Coax cable with Fakra connector to this CVPM .
Use OBD Mx+ and Alfa Obd to program and enable the camera options , soft key for this CVPM under Body Computer and Radio .
I am pretty slow myself, have bought a power cable for this CVPM from
@Jimmy07 , ask him tons of questions and get this far.
Currently The Front Camera Calibration kept failing .
I am sure if we have the schematics, wiring diagram, canbus design, we would be able to understand which wire, ports that the vehicle canbus system receive the Camera signals, to enable it through the wires . The Uconnect 5.0 they make it easier by adding CVPM and get the Canera signal through it.
