2019 1500 bighorn
Crew cab, panoramic sunroof
Granite Crystal , tinted glass
LED headlight package
Tow package 3.92 gears
Ram Crome nerf bar.
Revolver X4 rolling hard tonneau cover
Box spray in rhino liner
20’ x 9 +2 Fuel Contra rims
285/60 r20 Nitto EXO grappler tire
Daystar level lift in front 2” with DIY level sensor links .
I'm thinking of leveling my quad cab and putting the same tire size on. How's the ride and do you like the way the leveling kit turned out?
Honestly, the ride was great at 1st but after a while my tires got cupped . I think it was the EXO’ s fault not the lift though . I always found that truck a little too “supple” tbh
Baaaarely. The antenna seems to just clear but man it's close. Honestly, I haven't even fully pulled it in to test Ever since I got rid of my 3rd 'fun' car and got my wife a new car, she gets the garage.
If its close I'll let some air out and make it fit. My previous truck was a F350 crew cab long bed and I could only get it in with smaller wheels at a crazy angle.
It was frustrating and time consuming. Your truck looks fabulous 🤪
I'll check it closer if I ever get my garage back from the missus! It would fit but I do have a slight grade and bump getting into the garage as my house is on a slab. A little air out of the tire would definitely do it in a pinch. My last truck, 2018 Laramie w/ Rambox did fit but I had to get it within an inch of the back wall to close the garage door.
ETA, thanks. I got the idea for the tire size from this video: RAM Covert
I've got a falcon shock/strut kit I need to install. Its adjustable from stock to 2.25 lift. My plan in my head is to get a 2 inch spacer so it should be able to see a 4.25 inch lift. If it actually plays out that way is another story, but its going to happen soon. 🤪
Kiss them CV axles good bye!! Lol
