Hopster
- Mar 10, 2025
No surround view camera or cargo cameraSurround view cameras, or not? If not, do you have a cargo camera, or no?
Your CHMSL with camera will be 68465996AA.No surround view camera or cargo camera
Do you have any other part numbers? I can add all of them to the top. Also, any additional info you see might be missing?Your CHMSL with camera will be 68465996AA.
Follow the first post for your mirror part number.
I’ll pm you a mini writeup for the HD guys that you can paste into the 1st post. It’s really the same install/bcm requirements as the 1500’s, just a few different CHMSL part numbers.Do you have any other part numbers? I can add all of them to the top. Also, any additional info you see might be missing?
only the digital mirror the chmsl of 2500 does not fit in 1500So the 1500 parts fit the 2500 the same?
The camera in that brake light part number is incompatible with that digital rear view mirror.I have a 2022 Ram 2500 and purchased the DRVM camera kit from Infotainment.com. I don't have ACC or FCW.
Mirror: 68448639AB
Brake Light: 68552689AA
FAKRA Cable to connect mirror to brake light
Everything I've read online/talking with customer service at Infotainment.com suggests this should just be a plug and play. I get the attached screen when I flip the mirror to the camera feed. I have triple checked all the connections and even tried another FAKRA Cable. Does the 2022 need a separate BCM to work? I was under the impression you just connected the brake light camera to the mirror and it would work.
Any help would be greatly appreciated!!!
Thank you
You're the best!!The camera in that brake light part number is incompatible with that digital rear view mirror.
That brake light can only be used with the 2023+ digital rear view mirror 3.0.
No. Check post #2 to pick out the correct CHMSL for your truck.You're the best!!
Would this be the correct CHMSL: 68551077AB
Yes, just like it says in the first post.Excellent. Thank you!!
Since I have a 2022 it should be plug and play correct? No need to connect anything separate to the BCM.
No, different camera. You can run it to the second camera input on a dual mirror.Would I be able to just order the camera and wire run it to my CVPM and get it to come up on my Navi screen on a 2021 TRX with updated screen/module UC5 running I have 360 camera currently and wanna add cargo cam
Hello there, I’m looking to upgrade to the digital rear view camera but I’m not really familiar with how to do so. Would a service center be willing to install it?68551077AB
What are these green and yellow lines for. I don’t have them on my truck. I am also having problems to display trailer tow camera.Not a chance if your truck did not come factory equipped with a digital rear view mirror.
68508050AD is the part number of the digital rear view camera processor that comes installed in a 2023+ HD Ram factory equipped with a digital rear view mirror, and is located under the driver seat.
I think the Jimmy harness is only for the 19-20 years that require a signal from a BCM prior to those years
