HOW TO: Add Digital Rearview Mirror
Your CHMSL with camera will be 68465996AA.
Follow the first post for your mirror part number.
Do you have any other part numbers? I can add all of them to the top. Also, any additional info you see might be missing?
I’ll pm you a mini writeup for the HD guys that you can paste into the 1st post. It’s really the same install/bcm requirements as the 1500’s, just a few different CHMSL part numbers.
I have a 2022 Ram 2500 and purchased the DRVM camera kit from Infotainment.com. I don't have ACC or FCW.
Mirror: 68448639AB
Brake Light: 68552689AA
FAKRA Cable to connect mirror to brake light
Everything I've read online/talking with customer service at Infotainment.com suggests this should just be a plug and play. I get the attached screen when I flip the mirror to the camera feed. I have triple checked all the connections and even tried another FAKRA Cable. Does the 2022 need a separate BCM to work? I was under the impression you just connected the brake light camera to the mirror and it would work.
Any help would be greatly appreciated!!!
Thank you
Mirror: 68448639AB
Thank you
The camera in that brake light part number is incompatible with that digital rear view mirror.
That brake light can only be used with the 2023+ digital rear view mirror 3.0.
You're the best!!
Would this be the correct CHMSL: 68551077AB
Excellent. Thank you!!
Since I have a 2022 it should be plug and play correct? No need to connect anything separate to the BCM.
Would I be able to just order the camera and wire run it to my CVPM and get it to come up on my Navi screen on a 2021 TRX with updated screen/module UC5 running I have 360 camera currently and wanna add cargo cam
Yes, just like it says in the first post.
No, different camera. You can run it to the second camera input on a dual mirror.
I am hoping I can ask a question about a 2021 3500 on this site. I recently bought a 2021 Limited Laramie 3500. It came with a digital rear view mirror that has not worked since we got the truck. I took it apart and noticed that the coax cable was cut between the external connector and the internal connector. Also the 5 wires that run between the external 10 pin connector and internal 12 pin connector were pulled from the internal connecter and taped together. I have tried to find a diagram on the pinout on the 12 pin connector, but have not been able to yet. I am hoping someone can help me with this so I can get it hooked up correctly. Rear view mirror model number #68448641AB
Not a chance if your truck did not come factory equipped with a digital rear view mirror.
68508050AD is the part number of the digital rear view camera processor that comes installed in a 2023+ HD Ram factory equipped with a digital rear view mirror, and is located under the driver seat.
What are these green and yellow lines for. I don’t have them on my truck. I am also having problems to display trailer tow camera.
Hey everyone, thanks for all of the information. I have a 2022 ram 1500 and I'm looking to do the digital rear view mirror with two cameras. One that would be all the parts from the first post including the camera in the brake light module, but the second would be a trailer camera and a wire to run to the bumper.
I had read somewhere someone posted that you need a 30-ft female to female factor cable for that. What I don't know is what are the part numbers for me to add the actual port into the bumper so that I could connect a camera for the trailer camera.
The second part of my question would be what would I order for the actual trailer camera that I can install on the back of our camper?
Also I suppose I'm a little confused on the wiring harness and whether or not I need it from jimmy07. Also if anyone has a link to a video of someone doing this or instructions for where all of the existing components are that would be awesome.
I think the Jimmy harness is only for the 19-20 years that require a signal from a BCM prior to those years.
Cool, still need to figure out the trailer camera and bumper port. I see a trailer wiring kit for a backup camera 68527599AA that is for a 2500, not sure if that is for on the trailer or if that is the wiring for the length of the truck. I'm guessing it is the trailer. Need to know what to do to get the wiring on the truck or confirm that.
