theblet
- Feb 8, 2021
Ok I don’t have this, all good. ThanksThemes are under display options on the 12* screen
Probably get better answers on the HD Rams forum, but the red cable won't work well for you as the SGW is located behind rhenfushe cluster, and not down by kick pacnel like on the 1500sCan anyone clear up what bypass cable I’ll need for a 2500? I have a 22 Ram 2500 and have seen some back and forth on the red cable (mentioned in the thread from Amazon) compared to the type of cable connecting behind the headlight switch.
Thanks!
Good old’ YouTube University!Can anyone clear up what bypass cable I’ll need for a 2500? I have a 22 Ram 2500 and have seen some back and forth on the red cable (mentioned in the thread from Amazon) compared to the type of cable connecting behind the headlight switch.
Thanks!
Thanks!
If you’ve got a 2019+ 1500, non-Classic, then select DT. DT is the 5th Gen, DS is 4th Gen (which includes the Classic).Does it matter which model 1500 you use for adaptation, Ram DS, or Ram DT? What's the difference?![]()
Go to hdrams.com and ask there. This is a 1500 groupJust swapped out my halogen lights on my 21 2500 to oem Laramie LED housings, what setting do I need to change in the JScan app to enable the signature lights on all the time?
what you mean by: I configured the brake light alternate blinking with turn signal (haven't checked that yet).Played around a little bit this morning. I turned the fog lights on with the high beams. I configured the brake light alternate blinking with turn signal (haven't checked that yet).
I was also messing around with the daytime running lights. In the end I ended up turning them off via the screen settings because I like the look of the halo lights.
Probably will mess around with the demo area and see what else I can do. Lots of things to mess with. Seat belt chime, horn going off with remote start…. Not sure where to go?
I believe he is talking about my post here:what you mean by: I configured the brake light alternate blinking with turn signal (haven't checked that yet).
Yes to both. As long as you aren't on the newest application version for UC4, if you have UC4. You can change the steering wheel material and also go to a high/low, or high/med/low with alfaObd settings.is there any way to set a lo/ med / hi for the steering wheel heater? or lower the threshold for how warm it gets?
CAN IT BE DONE ON JSCAN I DO NOT USE ALFAYes to both. As long as you aren't on the newest application version for UC4, if you have UC4. You can change the steering wheel material and also go to a high/low, or high/med/low with alfaObd settings.
Dude why does it bother you that much?Dude, please turn off your caps lock.
